Ignition does not turn to off until I jiggle the Gear Shifter
Old Dec 13, 2017 | 10:26 AM
agupta3224's Avatar
19MDX_ADV
I am sure this question has been answered, but I am not able to find the answer.
Please someone point me in the right direction.
Here is the problem:
When I turn the Ignition to OFF it will not turn. The car is off, and in Park. Once I jiggle the shifter, the ignition turns to OFF easily.
I remember a mechanic once telling me that it is a sensor on the shifter that needs to be cleaned or replaced.
Any help is greatly appreciated.
Old Dec 23, 2017 | 04:24 AM
Matt W's Avatar
There is some sensor in the sensor in the shifter that won't let you start the car until the shifter is "fully" in park. I run into this issue sometimes when I have a USB cable that gets stuck between the shift guide and the shifter causing the shifter to not be fully in park, I have to get the cable unstuck before I can turn the ignition.
Old Dec 23, 2017 | 08:33 PM
projektvertx's Avatar
I have this issue happen with my Camry every so often. I chalk it up to age, but I'd assume it's the shifter not being "fully" in park as Matt mentioned.
Ryley
Feb 27, 2016 03:47 PM
StonedCL
Jan 15, 2009 04:22 PM
simplytltypes
Jun 22, 2005 01:48 AM
sstsx
1G TSX Problems & Fixes
Aug 19, 2004 02:07 PM
