I need wheels
Old Apr 15, 2015 | 10:21 AM
JohnDillinger's Avatar
I need wheels
I tried a couple different wheels but not fitting, I have 1 set I threw in there just cause they fit. Any suggestions on how I can find a set KNOWING they will fit without spacers? Any help is appreciated!
Old Apr 15, 2015 | 10:22 AM
math.
Old Apr 15, 2015 | 10:23 AM
you have to know what the stock wheel specs are.
then, use math to figure out how far the proposed set will either stick out or be sunken in.
Old Apr 15, 2015 | 10:27 AM
It seems like only concave wheels fit, but I'd like to get some kind of lip if possible. Maybe bigger would give more clearance? What's the biggest u can go?
Old Apr 15, 2015 | 10:28 AM
stock wheels are 17x8 +55, I believe.
bolt pattern is 5x120
then use an online wheel offset calculator to calculate how far in or out the new proposed wheels will be.
1010TIRES.COM - Wheel Offset Calculator
Old Apr 15, 2015 | 10:30 AM
use the online wheel offset calculator to determine how far in or out the new wheels will be.
then, you can use a ruler or measuring tape on your current wheels to visually see.
Old Apr 15, 2015 | 12:30 PM
oo7spy's Avatar
Wheel specs do not cover the thickness or shape of the spoke. Since offset is from the hub to the edge of the wheel, a thicker spoke wheel (or one with concave shape) may not fit even if the offset is the same as a thinner spoke wheel.
Numbers alone cannot guarantee fitment.
Old Apr 15, 2015 | 12:45 PM
NathanJax's Avatar
The first set I ordered didn't fit because of the thickness/shape of the spokes. Same measurements of the other rims I test fitted and same measurements of the rims I currently have. That's why I have the wheels I have now. Unfortunately, there's no "hey order this offset and it'll work".
Maybe you can get the shop to order the rims and if they don't fit send them back...
Old Apr 15, 2015 | 01:00 PM
Lots of different aspects when buying wheels
Old Apr 15, 2015 | 01:31 PM
HEAVY_RL's Avatar
RonJon Sport Design
Old Apr 15, 2015 | 01:51 PM
Yes I had them send 2 sets back already and I actually felt bad giving them a hard time cause they wanted to use spacers but I'm not ok with that and guys in the shop even said they didn't advise it. All measurements was same.
Stock rim is 17x7.5 35mm positive offset.
I thought some RL owners would've known of some suggestions.
Old Apr 15, 2015 | 01:57 PM
modding is personal.
wheels are very subjective, get what you like but also get what fits.
you can also go through past threads here on acurazine to pick out wheels that you like and that fit.
Old Apr 15, 2015 | 02:37 PM
oo7spy's Avatar
Not on the RL. The TL wheel is (edit: not) 7.5". The RL is 8".
Look for brands that cater to BBKs. 90% of TSW wheels will clear the front calipers. RonJon, like heavy mentioned, caters to Honda and Acura products and will give a manufacturer guarantee.
Did you bother looking in the Tires, Wheels and Suspension sub-forum?
https://acurazine.com/forums/tires-w...wheels-806687/
Old Apr 15, 2015 | 02:39 PM
TL wheels are also 8" wide
Old Apr 15, 2015 | 02:40 PM
oo7spy's Avatar
3g?
Old Apr 15, 2015 | 02:41 PM
17x8 +45, yessir!
Old Apr 15, 2015 | 02:46 PM
oo7spy's Avatar
Hmmm... I guess I was confusing that the TL Aspecs are only 17" while the RL are 18". In any case, the OP does not have stock 7.5" wheels. Edited my post too.
Old Apr 15, 2015 | 02:50 PM
^did i get it right in post #5? if not can you edit that for me?
Old Apr 15, 2015 | 03:01 PM
oo7spy's Avatar
According to Bob, the RL offset is +55. Post 5 corrected.
https://acurazine.com/forums/tires-w...7/#post7493944
Old Apr 15, 2015 | 06:19 PM
So what's the actual size from a stock 2nd gen? Shop told me 17x7.5 +35, some say 17 8 +45, +55. Here under suspension it says 17 8 +55.
Old Apr 15, 2015 | 06:43 PM
oo7spy's Avatar
justn said 45 and he was going off of the TL. Trust Bob. He says 17x8 +55.
Your shop is 100% wrong.
Old Apr 15, 2015 | 07:47 PM
Motegi has the wheels I've been looking to fit, I'm wondering if he used spacers
Size:  878.6 KB Wheels I have now I wasted time and money on, I mean there not bad but I like the old school lip/dish
Old Apr 15, 2015 | 07:57 PM
He might have mistaken but they do know their sht, he said it's an issue with Lexus and Acura big brakes. I told him 1 buddy's TL had no problems but my other buddy same TL as buddy 1 has the same problem I have. He told me something I never knew, he said 1 must have a manual or typeS and the other automatic and he was right so he must know a little something about Acura's. All I ever owned was Acura's and I never knew that
Old Apr 15, 2015 | 09:28 PM
John, i checked out the MRR - GT1 wheel and it comes in two widths in the 20" designation.
so you have a 20x8.5 and a 20x10.
and then you can choose offset.
this means; you'll need to play with the offset calculator I linked above to figure out where the perfect offset you need to be at to be flush.
Old Apr 15, 2015 | 09:31 PM
not gonna lie; its a lot of fucking work choosing wheels.
and you already messed up your first set, so I advise you to keep looking at the wheel thread that 007spy linked till you can recognize how flush the or how sunken in the wheel will be with the offset provided
TL;DR
Study that thread till you're dreaming about offsets.
Old Apr 15, 2015 | 09:57 PM
rondog's Avatar
Former Sponsor
18" x 8" (5 x 120 with a +38mm offset) and an exclusive 64.1 Acura hub centric center bore.
19" with the same specs but with a +32mm offset but 38 will clear the calipers:
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
JByron
Jan 8, 2016 09:49 PM
GhostTL09
Sep 19, 2015 01:57 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
