Hvac
Old Nov 10, 2006 | 08:24 AM
db22's Avatar
Hvac
Has anybody tried the 4 point HVAC with any success? Try getting cool air to the driver vent and warm air to the feet and vice versa to the passenger. In theory it can be done but I'm not sure that it works as intended.
Old Nov 10, 2006 | 02:51 PM
db22's Avatar
May I assume:
1 - Nobody knew that you can get different temps from 4 areas?
2 - Nobody has tried it.
3 - nobody has a solution
4 - All of the above.
Old Nov 10, 2006 | 07:51 PM
plastikman's Avatar
5 - noone really cares
Old Nov 11, 2006 | 03:27 PM
clangjr's Avatar
There is a limit in the number of degrees you can request from one seat to another.
Old Nov 11, 2006 | 04:44 PM
dwboston's Avatar
Go to the 2005 RL owner's manual here: https://techinfo.honda.com/rjanisis/...505O00162A.pdf
Then go to page 166. There is a diagram that shows how to do it.
Old Nov 14, 2006 | 07:32 AM
db22's Avatar
Thanks, but I know how to do it. I was wondering if anyone had tried it and how well they thought it works. It's a nice feature but it is difficult to tell the temperature difference in 4 zones.
Old Nov 14, 2006 | 08:38 AM
clangjr's Avatar
As I stated above, there is a max delta in temperature difference, which I believe is 10 degrees. Most males are only able to sense a 5 degree shift in temperature (females can sense 2-3 degree shifts). So a 10 degree difference from one spot in the car to another for a male isn't going to mean a whole bunch.
Old Nov 14, 2006 | 09:32 AM
jftjr's Avatar
'06 RL
The entire point of multi-zone heating is for women. Only women can be warm up top and have cold feet.... Meanwhile, the male in the car will have heatstroke at any setting sufficiently thermally optimized for a female.
Old Nov 14, 2006 | 09:01 PM
2veloce's Avatar
Too Funny - but so true
Old Nov 15, 2006 | 09:15 AM
db22's Avatar
So what your saying is that it does mean a Hole bunch to a female!
Old Nov 15, 2006 | 02:01 PM
clangjr's Avatar
Simple solution:
1) If you are a female, become a male
2) Wear socks
Jul 16, 2017 07:33 AM
urbtsx
Sep 27, 2015 09:40 AM
doopstr
Home & Garden
Sep 12, 2007 10:08 PM
afici0nad0
Nov 16, 2006 10:46 PM
