HID High Beam - Is it possible ?
Old Feb 15, 2009 | 01:42 AM
sasovics's Avatar
8th Gear
Hi folks,
I am speculating to upgrade my halogen DLR/High Beam to HID. Is it possible ? If so what would you suggest ? What bulbs do I need to buy ? And where ? Does such an installation needs some hard modification to my head lamps ? I know HID are unable to run on low power so they will not work properly on DLR, but I am willing to sacrifice the DLR for HIDs. Has any of you accomplished this on an RL before ? Any specific information (or link) about such an upgrade would be appreciated. Many thanks in advance!
Regards,
Sasovics
Old Feb 15, 2009 | 08:02 AM
037's Avatar
037
I am doing the exact samem thing. Here's what I will be doing today.
I have an el cheapo HID kit off ebay for $60 shipped. Plain old regular installation into DRL/High beams.
Now at low voltage the lights flicker (already tested that), so what you basically do is drive around normally with low beams on.
When you hit High Beams, the lights will come on at full power, and that's what you wanted.
Old Feb 15, 2009 | 08:43 AM
sasovics's Avatar
8th Gear
Oh great!
Please update us with your final results! Some pics would be appreciated as well! Good luck mate!
Old Feb 15, 2009 | 08:55 PM
037's Avatar
037
Here's your answer:
DRL
High Beams
Old Feb 15, 2009 | 09:56 PM
037's Avatar
037
that's PIAA Super Plasma GT-X, mechanic wasn't working today so I didn't get the chance to drop in HIDs, photos next weekend. By then I'll probably replace stock low beams with 8k's as well. My fogs make them look sad.
Old Feb 16, 2009 | 05:48 PM
T-jay's Avatar
im baaaack!!
I just put yellow 9005 raybrigs for the jdm look. Hqad the shop do it cause this isn't a civic so i didn't know where to start,lol!
Old Feb 16, 2009 | 10:11 PM
037's Avatar
037
"10k" HID High Beam:
Setup took about 20 mins by a professional, had to put 1 hole on each side for balasts.
Old Feb 17, 2009 | 07:47 AM
sasovics's Avatar
8th Gear
Wow, looks beautiful! So you sacrificed the DLR for HIDs hi-beams. Would you mind post the details where did you buy these bulbs and for what price ? Also I notice the color temperature of your hi-beam HIDs is higher (more blueish) then your low-beam HIDs. I suppose this is beacuse of 10k vs 6k. Are you gonna change the low-beam HID bulbs to 10k as well ? Anyway, does higher color temp light bulb provide better luminance as well or just give more blueish effect ? Thanks
Old Feb 17, 2009 | 08:02 AM
037's Avatar
037
1. Yes, DLRs had to go as HIDs at lower power blink faintly
2. Bought the lights off ebay, a simple search for bulb size and words HID would get you results of bout $60 for the kit (buy from a US seller as shipping times may be weeks from overseas)
3. Low beams are in the range of 4k which makes them look yellowish compared to 10k
4. Yes, I just ordered a set of 8k bulbs for low beams and will install them on the weekend
5. The best luminance comes from the factory lights. Everything else, 6k and up specifically will lose out some brightness and will provide a little more color.
Old Feb 17, 2009 | 08:29 AM
sasovics's Avatar
8th Gear
Just for confirmation: The bulb size I shall order is 9005 ?
Old Feb 17, 2009 | 09:12 AM
037's Avatar
037
I'm not 100% what size your car has, but mine are H8 fogs, 9005 DRL/High Beam, D2S low beam.
Old Feb 17, 2009 | 09:30 PM
T-jay's Avatar
im baaaack!!
The RL is 9005 hi beam and H11 foglight bulb!
Old Feb 17, 2009 | 09:56 PM
037's Avatar
037
I got the 09, which is what I said
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
