Help, 08 RL started on its own
Old May 16, 2013 | 11:48 AM
PVD24's Avatar
Hi everyone, here is the back story.
I was showing a fellow worker how my swiping of the back of hand locks my car. I showed him a few times, and then we walked away and my 2008 Acura RL started. I didn't even know how to shut it off. I stepped on the brake and it finally shut down. I bought it used so I honestly don't know if it has a remote starter. I checked under the column and didn't see anything. I repeated the process and swiped 3 x and walked away and the car started again.
How do I find out if I have a remote starter?
Old May 16, 2013 | 12:31 PM
M T L T L's Avatar
Damn son, if you could reproduce that with the key fob, u w'd got urself a remote starter and forget about it.
Old May 16, 2013 | 12:38 PM
HEAVY_RL's Avatar
first off, you gunna burn up the handles like that.
Second, video or GTFO
Old May 16, 2013 | 12:49 PM
PVD24's Avatar
Tried everything on the key fob - no go
But I did find a little bag with paperwork that says Code Alarm CA 410A
Remote starter. I need to figure this out!!
Old May 16, 2013 | 01:09 PM
HEAVY_RL's Avatar
http://voxrightnow.custhelp.com/app/...-start-upgrade
Remote Starting The Vehicle: Press and release the proper button or combination of buttons on your transmitter to activate the remote start system. The vehicle will start and remain running for the pre-programmed 10 or 15 minutes.
I assume you are tricking the car into thinking you are pressing lock and unlock.
As a visual indication, the parking lights will flash or turn on depending on the programming set up by your installation center.
Doe this happen?
When you arrive at your vehicle, unlock the vehicle by pressing and releasing the unlock button of your keychain transmitter or by use of the vehicle key. Enter the vehicle and turn the ignition key to the ON position. CAUTION! Do not turn the key to the start position. This will cause the starter motor to engage with the running engine which could result in damage. Step on the brake pedal to disengage the remote start unit. The vehicle will continue to run on it's own power.
NOTE: The engine will stop running before the expiration of the pre-programmed run timer if you complete any of the following:
  • Pressing the proper button or buttons of your transmitter while running under control of the remote start system will turn the vehicle off.
  • Depress the vehicle's brake pedal.
  • Open the hood.
  • Move the red handled control switch to the OFF position.
  • Race the engine to above 4000 RPM.
Does this work?
OPERATING ON AUTOMATIC START TIMER MODE: The system has the ability to automatically start the vehicle every 2 or 4 hours over a 48 hour period. This feature is especially useful in cold climates where the only means to keep the engine and engine fluids warm is to periodically start the engine.
I would remove this starter.
Old May 16, 2013 | 01:17 PM
PVD24's Avatar
Going outside to try again, I'll keep ya posted
Old May 16, 2013 | 04:11 PM
HEAVY_RL's Avatar
Regardless of the situation, this feature would make me very nervous due to the risk of a malfunction.
Old May 16, 2013 | 04:40 PM
mitchkramez's Avatar
Yeah, stepping on the brake should kill the remote start... if it doesn't, you def want to remove the remote starter b/c it wasn't installed properly, and who know what else could be borked up in there.
Old May 16, 2013 | 05:55 PM
interesting thread.
Ive heard of previous owners leaving change or old french fries; but this must have been a surprise!
Old May 16, 2013 | 06:56 PM
PVD24's Avatar
Total surprise, still can't turn it on by what I did earlier. I tried every combination on my key fob.
To someone who posted before, the brake did shut it down. I'm hoping I can figure it out.
Old May 16, 2013 | 07:25 PM
PVD24's Avatar
Hope that link works so you can see what is happening.
I hit the unlock button on the fob and then the lock button on the door and then the car starts.
Old May 16, 2013 | 07:31 PM
oo7spy's Avatar
There has to be a fob combination (think Nintendo cheat codes) that will do it. Otherwise the word remote is very relative to your setup.
Old May 16, 2013 | 07:33 PM
Just found this on some Toyota RAV4 thread about the CA410a:
Hit "lock" twice within 2 seconds, pause and then hit "lock" again and it starts. in their OEM remote situation... perhaps that's how it's setup?
Also, apologies - i misread the initial post and thought it said that the brake DIDN'T shut it down
Old May 16, 2013 | 07:36 PM
PVD24's Avatar
Going to try it now
Old May 16, 2013 | 07:46 PM
PVD24's Avatar
I tried that combination and it didn't work. I'm guessing since I unlock the door with the fob and then lock it with the handle that both the unlock and lock have to be used in this Contra up down up down sequence. Aggravating
Old May 16, 2013 | 08:43 PM
Carbon Legend's Avatar
Lock unlock Lock quickly
Old May 16, 2013 | 10:41 PM
BDoggPrelude's Avatar
Craziness. The weird thing about that is there either has to be a key fob somewhere in the car or the system somehow tricks the car into thinking there's a fob inside. Kind of makes me wonder how secure the car is and if it could be started without having the fob in the car...
Old May 17, 2013 | 07:13 AM
HEAVY_RL's Avatar
stand on one foot
Old May 17, 2013 | 07:35 AM
Let me rephrase that. I wonder if it can be started without the fob at all. OP, have you tried getting in the car and turning the ignition switch without having the fob on you?
Old May 17, 2013 | 10:03 AM
oo7spy's Avatar
Left, Up, Right, R, Up, Left, Up, L, Down, A
Old May 17, 2013 | 10:06 AM
PVD24's Avatar
Car will not start without the FOB, it's definitely a code that I'm missing on the FOB, tried everything
Old May 17, 2013 | 10:20 AM
oo7spy's Avatar
From my understanding of Megatron's explanations, at a minimum, the car needs either the fob and the dummy key (knob) or the RFID transponder in the physical key base and the physical key to turn the ignition to (II). The last part is the most important. The car cannot be driven (or shifted out of park) without the ignition set to (II). The starter only needs an electrical signal to start the engine, so the engine can be started without any of the fob, key, or transponder. However, you can't go anywhere unless you can turn the ignition.
Please tell us (or PM me) if you find the combination. My truck supposedly has a remote starter, but I can't figure out the combo either. I'll let you know if I find out.
Old May 17, 2013 | 12:36 PM
M T L T L's Avatar
"Adooou Ken"
Old May 17, 2013 | 12:59 PM
HEAVY_RL's Avatar
Finish him.
Old Nov 25, 2013 | 09:14 PM
PVD24's Avatar
I know this is a few months later, but I finally figured out the steps to starting my car. It was Lock, Unlock, Lock slowly. After 2 seconds, the car starts on its own. Now my issue is, I get into the car and cant move the ignition to switch to be able to press on the brake without it shutting off. Im on to the next piece of the puzzle.
Old Nov 26, 2013 | 07:25 AM
oo7spy's Avatar
A worthy student you are.
Old Nov 26, 2013 | 07:44 AM
HEAVY_RL's Avatar
This thread is the slowest win ever.
Old Nov 30, 2013 | 09:26 PM
Mr.RL's Avatar
I skimmed this quickly but i have a question, what'd the dealer or other reputable mechanic location have to say? Or was that not factored in?
Old Dec 5, 2013 | 08:23 PM
PVD24's Avatar
I never brought it to a mechanic. No need to. It's running really good. I may have solved the rest of the mystery. So I am ae to remote start it from far away and when I get in I either press on the brake and shut it off and then restart it or I take the valet key out and move the ignition switch. Problem solved
Old Dec 6, 2013 | 11:38 AM
vletnguyen's Avatar
I have my remote start set up to where it will start when the lock button is pressed three times in a row. I did this so I didnt have to carry around an extra FOB and just used the OEM one. The OEM FOB's range sucks though.
rockyboy
Aug 4, 2024 10:35 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
jordanboi
Sep 5, 2015 01:33 AM
