Had my motor mounts replace
Old Apr 2, 2015 | 08:38 AM
grip1968's Avatar
I took my 05 RL up to the dealership to have my front and side motor mounts replaced. Now everytime I accelerate I'm hearing this humming noise coming from the front of the car. Anyone every experience this when having your mounts change. The dealer can figure out what's wrong..
Old Apr 2, 2015 | 08:58 AM
oo7spy's Avatar
May not have anything to do with the mount replacement. Can you be more specific about the symptoms?
Old Apr 2, 2015 | 09:09 AM
because the tech's did go in and perform slight surgery, they could have not put something back or damaged another part but not necessarily isolated to motor mounts.
some one will have to diagnose or further deduce where the noise is coming from...
there is just too little information to diagnose over the internet, as it could be MILLIONS of things.
Old Apr 2, 2015 | 09:21 AM
grip1968's Avatar
It only stop making this humming noise when I accelerate, when I'm coasting I don't hear it. It sounds like something is not tight,etc...
Old Apr 2, 2015 | 09:25 AM
because of the recent work that was done; something might not be hooked up correctly....
or some one left some tools in the engine bay.
or.....some one damaged another component inside your engine bay....
or a vacuum hose wasnt hooked up.....
there's literally thousands and thousands of reason why your car is humming when in drive.
Old Apr 2, 2015 | 09:26 AM
some one will need to look at your car and determine where the noise is coming from.
which we cant do over the internet.
Old Apr 2, 2015 | 10:14 AM
titomang's Avatar
If the noise wasn't there before you brought it to the dealer to change out your mounts then it's most likely related to the install of the mounts. Bring it to the attention of the dealer who perform the repair.
Old Apr 2, 2015 | 01:07 PM
grip1968's Avatar
I took it back to the dealership this morning, I give an update once I here from them..
Old Apr 3, 2015 | 12:49 PM
grip1968's Avatar
Ok,I got my car back from the dealership. The problem was there was debris from the old motor mount hitting up against a shield. Now it drives good again.
bnaritomi
Feb 17, 2016 03:22 AM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
