Fuel filter
Old Oct 11, 2011 | 01:13 PM
lilryan's Avatar
Fuel filter
where is it located on the 05 rl. is it even servicable. i cant find one. i know there is one on the fuel pump in the tank, but all the other hondas i had had one in line as well that could be changed.
thanks
ryan
Old Oct 11, 2011 | 03:19 PM
oo7spy's Avatar
Have you taken a look into the service manual? It is posted in the Garage Sticky.
Old Oct 11, 2011 | 04:32 PM
techtalk's Avatar
Lilryan,
The fuel filter on a '05 RL is located within the fuel pump, which is located inside of the fuel tank. You would have to remove the fuel pump in order to access the fuel filter.
For a visual reference, the fuel filter is depicted as ref #4 and the fuel pump is depicted as ref #16 in the diagram below:
*diagram courtesy of acurapartswarehouse.com; all rights reserved
Old Oct 11, 2011 | 05:21 PM
lilryan's Avatar
thanks guys. i guess i wont be changing it.
Old Oct 13, 2011 | 01:25 PM
EL19's Avatar
Ive changed the fuel pumps on these acuras. Not too difficult. So if you really wanted to change the filter it wouldnt be too hard.
Old Oct 13, 2011 | 02:23 PM
lilryan's Avatar
its not that big a deal to me. ive done pumps in lots of hondas, just not one of these.
Old Oct 13, 2011 | 03:14 PM
DanL07RL's Avatar
I aksed my dealer and they said not to replace it!!
Old Oct 13, 2011 | 04:35 PM
lilryan's Avatar
wonder why
Old Oct 13, 2011 | 10:57 PM
danmm7's Avatar
Where do we buy it?
Is the fuel filter actually sold as separate part at the dealer? Does anyone know the part number for the RL?
I've replaced the fuel filter on a Nissan Maxima 3.5L and the idea was the same. Filter was inside the fuel pump assembly. I got it replaced on my own in less than 1hr time. At 82k miles, the filter was VERY dirty.
I am thinking about doing the same thing with the filter on the RL, as long as i can buy the filter from somewhere and get a detailed diagram of the pump assembly. I wonder if there're any tricks.
Old Oct 14, 2011 | 09:29 AM
oo7spy's Avatar
The trick is to drop your gas tank. It is a pain in the ass and will cost you $$$ in labor. Honda would not have made it so inaccessible if they felt it needed replacement. Run 91 grade or higher fuel, and you should not have any problems.
Old Aug 19, 2014 | 08:27 AM
JDMCRX's Avatar
I know this a old thread but if you look at part #21 there is a access panel to access the fuel pump so changing the fuel filter should be like the rest of the new cars out there unhook the lines and pull the pump out.
I will do a DIY fuel filter change soon.
Here is what the kit looks like .
Old Aug 19, 2014 | 08:46 AM
Nersh7's Avatar
I Drive Like A Dick 8≈
Looking forward to the write up. How much did the new filter cost you?
Old Aug 19, 2014 | 09:50 AM
JDMCRX's Avatar
In canada its $86 in the US its like $36 so im ordering it online and shipping it to the boarder.
Old Aug 19, 2014 | 12:15 PM
ksu1018's Avatar
you do not have to drop your fuel tank. To get access to the fuel pump/filter you simply remove the rear seat. you will see to access covers. one of them is for access to the pump/filter. I replaced my pump about a year ago. it was easy. it maybe took an hour.
Old Aug 20, 2014 | 09:08 AM
oo7spy's Avatar
I have since learned about the back seat access.
Old Jul 9, 2015 | 09:24 AM
thomask's Avatar
Hey guys,
What's the consensus on fuel filter. In SM it tells you to replace it after 8 years or thereabout. Is it worth doing?
Old Jul 9, 2015 | 09:46 AM
oo7spy's Avatar
What part of the SM did you read that? The Fuel Supply System section says, "The fuel filter should be replaced whenever the fuel pressure drops below the specified value, after making sure that the fuel pump and the fuel pressure regulator are OK."
Old Jul 9, 2015 | 10:25 AM
thomask's Avatar
but it's true that once you go inside for details it says to check pressure...I guess this statement has got higher priority than "replace" at 8 years mark? Then again, why would they even bother putting it in the maintenance schedule after 8 years?
Old Jul 9, 2015 | 01:24 PM
oo7spy's Avatar
I'm just interested in what copy of the service manual you have.
Old Jul 9, 2015 | 04:01 PM
thomask's Avatar
It's a European version for Honda Legend (which is USA's Acura RL). Is it that in USA you don't have this replacement in maintenance schedule at all?
Old Jul 9, 2015 | 05:03 PM
rlerman's Avatar
That is very different than the RL. Timing belt is 105k miles, for example, and engine oil is 7500, roughly, not 9. I would not follow that for the RL.
Old Jul 10, 2015 | 09:41 AM
oo7spy's Avatar
I'm willing to bet that is a direct translation from the JDM version the enginners put together, and it is the proper intervals. Honda of America probably adjusted everything down to increase dealer maintenance appointments.
thomask, that looks like a digital copy of the SM. Do you mind sharing? If you don't want to do it publicly, I can give you an email.
Old Jul 10, 2015 | 10:48 AM
thomask's Avatar
I don't mind sharing it but the whole SM weighs ~2GB. Any ideas where to upload it?
Old Jul 10, 2015 | 12:20 PM
oo7spy's Avatar
Google Drive, Drop Box or Media Fire.
Old Jul 17, 2015 | 03:56 PM
thomask's Avatar
Finally. Hope it works guys - digital copy of SM for EU:
https://drive.google.com/file/d/0Bzm...ew?usp=sharing
It's pretty cumbersome to use, though. I open it up in IE (nothing else works). Then you have to change language to English (German is the default).
Old Jul 20, 2015 | 10:58 AM
TonyCD's Avatar
Personal opinion based on nothing: This car, as some have eloquently put it, is "one of the last of the great Japanese tanks." I plan on taking the approach of No Malfunction, No Replace Fuel Filter.
Old Feb 16, 2022 | 10:23 PM
fabioel99's Avatar
Can you upload it again?
kenester
Oct 1, 2016 02:53 PM
Tennisjon2002
Apr 14, 2011 09:24 PM
harminder247
Mar 24, 2008 11:29 AM
97CLgenius
Jun 30, 2004 03:19 PM
3.2 TL
Feb 26, 2002 09:04 AM
