Frozen washer jets: Fluke or vulnerability?
I've had to park my RL out in the snow for the duration of a workday twice in recent weeks. Both times one or both washer jets froze over solid and would not begin working even after repeated applications -- which, of course, smear dirt in my field of vision and microscopically scratch the glass on every attempt. Ouch.
After the first episode, I sprang for the pricey Prestone stuff that's supposed to have the really low freezing point. No matter.
Anybody else out there have this problem?
Yes, this happened on my 2006. It was a major pain in the ass during the winter.
Where do you people live? I use "splash" and while I had crud freeze on top of the nozzles, I have never seen the hose or actual nozzle itself freeze up. As long as I clear the tops of the nozzle area while I am doing my windshield, they seem to spray fine. Coldest day I have operated the car was -24F. Can't recall any wiper problems, other than blade pressure which was the subject of a TSB.
um...that didnt actually do it for me, I remember keying it at one point and I think it made it worse.
Gonna have the dealer check it out as I am not happy with the way it sprays.
I am talking about when I go to lake Tahoe for snowboarding.. It happens when it is in the low teens or 20's ... definitely has occurred several times for me.. You can use < 32 windshield fluid, but I can't find it locally, unfortunately. Even looked in gas stations on way to tahoe but never found it..
That never worked for me. I had to insert a pin in the mechanism to make it work sometimes, but most of the time it was a matter of time. Again, annoying. In fact, I was hoping for heated washer fluid when I bought my V but the manuacturer went belly-up so it was mo longer a factory option.
I have never had it freeze up or clog to that point. What was really annoying was the lack of driver side blade pressure. I had the dealer do the TSB on that while they were changing my propeller shaft. Picking it up today, I hope it makes a difference- but no snow in the next few days to test unfortunately...
It happened to me pretty recently. I was picking the car up at the dealer after service and the tech. dropping the car off for me noticed that there was no spray, despite a full reservoir. The techs conferred and agreed that things were frozen and had no suggestions other than to wait. A few days later the temps finally rose and the spray has worked fine since.
weird, i have an 06, never had any freezing issue and i have left my car in lower than -20C weather with snow...a quick wipe and a couple of squirts clears it up...gotta make sure you use the good washer fluids.
i'm from toronto
i'm from toronto
I'm going to try something different.
I can't stop driving in snowy places, so I'm ordering one of those 12-volt blow dryers with the 8-foot cord. Next time it freezes, I'm going to pull over and try to thaw it out.
nanos
11-12-2015 08:41 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
