Engine cover rivets?
Old May 31, 2016 | 10:56 AM
stagefoursurvivor's Avatar
I just noticed the plastic(?) rivets holding the cover over the battery(drivers front section about 12X12") are broken, one completely missing and the other broken off with the shaft screwed in.
Anyone know what they're called, where to buy besides the dealer & how do I get out the broken shaft?
Old May 31, 2016 | 02:49 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
It does not appear there are replaceable rivets or fasteners for the cover. I assume they are on the underside from your description. Perhaps they were permanently attached and broken by someone removing the battery cover.
However you can replace the entire cover (part 6) for about $21 part # 31531-SJA-A02.
Or perhaps you are referring to part 22?
Old May 31, 2016 | 03:02 PM
Thanks.
Don't see a #22 and yes, I guess they're called twists. The P/N for the entire cover shows '08, does that fit the 2012?
Old May 31, 2016 | 03:10 PM
Originally Posted by stagefoursurvivor
Thanks.
The chart image I attached is from the 2012 RL OEM parts listing. So it must be the same part # from 2008.
Part 22 is on the far right margin of the parts image. It is the nut that holds the top brace over the battery.
Old May 31, 2016 | 03:25 PM
I'm missing two twists as you can see in the photos, plastic cover on & offEngine cover rivets?-unnamed.jpg
Old May 31, 2016 | 04:03 PM
Ah, gotcha. Those are just plastic panel clips. You can probably find them in an auto parts store. Here is an example from ebay:
http://www.ebay.com/itm/like/281471118769?lpid=82&chn=ps&ul_noapp=true
Old May 31, 2016 | 04:09 PM
100 Pcs Retainer Clips Fasteners Bumper Hood Fender Splash Guard for Honda Acura | eBay
Much obliged, I'll try autoZone, need new Bosch wipers for the wagon
gavriil
Aug 20, 2025 04:43 PM
Black Tire
Dec 18, 2017 08:15 AM
Mr. Showtime
Feb 8, 2016 07:27 PM
k1x
Jan 24, 2016 02:19 PM
GK83
Sep 13, 2014 12:48 AM
