door locking dimple not working
Old Nov 27, 2006 | 05:48 PM
kollamala's Avatar
Today I noticed that the door dimple on the passenger door does not lock. Has someone had this problem and what was the fix?
13,600 miles 2005 RL
Old Nov 27, 2006 | 05:55 PM
jfprl's Avatar
I had an intermittent problem with the drivers door. They replaced the handle and it has worked flawlessly since.
Old Nov 28, 2006 | 05:58 AM
ddswv's Avatar
My 2006 door dimples on both the Driver and Passenger doors would refuse to work anytime they had been wet a few hours beforehand. I had the driver's handle replaced, which fixed the problem, however, the shop evidently removed the door glass in order to replace the window. They had to take the car back a 2nd time to fix the alignment and trim around the window, and I then had to have my window re-tinted do to the scratches received when the window was removed during the install. Since the driver's door now works flawlessly and the experience received above, I did not have the passenger's door handle replaced.
Just a head's up!
Old Nov 29, 2006 | 05:04 AM
lland's Avatar
According to Websters, a dimple is a "small...hollow area or crease..."
Since these are raised spots on the door handles wouldn't they be "Nipples?"
LL
Old Nov 29, 2006 | 08:52 AM
medrxman's Avatar
LL
or perhaps a "PIMPLE"
Old Nov 29, 2006 | 09:35 AM
ddswv's Avatar
Ok, I was just using the terminology of the salesman.
Now I will never be able to lock the doors again without thinking about it. I don't know whether I can't wait to grab the nipple, or stay away from the pimple.
Old Nov 29, 2006 | 10:47 AM
lland's Avatar
If it is indeed a "pimple," I wouldn't push it too hard.
LL
Old Nov 29, 2006 | 08:02 PM
kollamala's Avatar
working now
Just a head's up!
Thanks for the heads up. It started working today morning. I had washed the car and it did not work for 1 day. Hope it will not be an intermittent problem.
Old Nov 29, 2006 | 08:42 PM
medrxman's Avatar
Unfortunately IMOP it will be!
tman570
Jun 11, 2019 07:56 AM
acurajj
Sep 19, 2015 03:47 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
drewdeezy03
Sep 3, 2015 08:04 PM
