Do you turn off the A/C when heat is on?
Turning the AC off will cause your windows to fog. Leaving the climate control on, and letting the AC cycle the way it was designed will allow the cabin to maintain the proper moister level.
06 RL - Carbon Gray Pearl
You are right
Thanks!
I let the AC system do its thing.
I keep mine on auto when it's cold but I don't think it uses AC when heat is on - I don't feel engine work harder then it's off and MPG is about the same. But it's definitely keeps windows fog-free :-)
I usually leave my AC compressor off unless it is really hot or the windows fog up.
The problem with that is that the AC becomes stinky when you turn it back on. With the rain and foginess here in SoCal, I am leaving the AC compressor on -- and hoping the smell subsides (and keeping my windows fog free).
I may just leave it on all the time for a spell.
Rob144
Rob144
Pretty much always on auto. Partly because the computer usually does a better job than I do, partly because the AC interface is a lot of button clicking unless you use voice, in which case it is auto anyway. I suppose there is a mileage hit. In the spring and the fall, and some summer days, the sunroof open is about the only time the climate control is off.
On some cooler days, bright sun, I have been known to keep the heat on and open the sunroof.
That is why I love this car, it keeps you well pampered.
I usually keep mine on auto, but I've been experimenting recently with a/c on or off and auto or manual because this is my first winter of ownership and the side windows fog up a lot. Still not found the answer. Any advice out there? The only thing that I have found that makes any difference to gas consumption is to drive slower.
With all cars i've had so far, i have found that the A/C being ON will affect the performance and the gas mileage - in a negative way. Is it s huge difference? Maybe not, but i sure can feel it. I lose about 1-1.5MPG if i run the AC all the time with the RL.
The AC compressor does put extra load on the engine and it will affect your gas mileage and it will make the car a bit more sluggish.
The more powerful the car is, the less you'll feel the effect of the AC being on. In other words, if you have a big powerful V8 under the hood and you run the AC, chances are there will be no noticeable difference in performance. However, if you have a 4-cyl engine or a V6 that is trying to move a HEAVY car (like my RL), any additional 'weight' on the engine will be noticed. A lot of people do not realize it, but the AC compressor requires a good amount of engine force to do its job.
Extra work for the engine is always equal to more gas being used - simple law.
I try to use the AC only when i need it. When it is not raining outside and the weather is cool - i use only the fan (AC off). If it's humid/wet/raining or hot outside - i keep the AC on. I rarely use "Auto".
LIST/RAMEN/WING MAHSTA 짱
Rob144
Rob144
Hopefully this solves the stench problem.
The rotary a/c compressors are more efficient then the old piston style. Leave the A/C on during the winter or rainy times so that you can keep the windows free. The A/C pulls moisture out of the air inside the car, and drains it out. When the outside air is in the 60's and 70's turn off the A/C if you are driving and just let the fresh air flow in, moderating the cold with the heat controls. You can turn off the a/c under the a/c button on the center console.
So, just leave everything in the Auto mode and just manually control the temperature, but leave everything else the same?
I am too having a very hard time with the window fogging up in the mornings driving to work. During the afternoon it's not too bad. At evenings when the family is in the car, it's about dangerous.
This is great information...I just want to make sure I'm understanding correctly.
Thank you all.
Cory
Thank you all.
Cory
Yes, that is correct and applicable to most cars. In three Acuras and my current Cadillac, I just leave the climate control on "Auto" and let it do its job. I have never had any mildew problems ever (or at least any severe enough for me to notice).
rockyboy
12-06-2022 02:29 PM
09-17-2015 09:01 PM
