Dash board display goes off an on
Old 06-16-2011, 07:57 PM
du0ngtl's Avatar
Does any one has the same problem with the dash board display goes on an off? Been doing this for a week already.
Old 06-16-2011, 08:29 PM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
Do you mean the odometer/MID, the display by the center channel speaker, or the Nav? Or all 3?
Is it going out when the lights come on by chance?
Old 06-16-2011, 08:58 PM
du0ngtl's Avatar
The one by the center speaker. It goes off even whit the lights are off
Old 06-17-2011, 08:01 AM
db22's Avatar
Yes, I had the same issue. The cloth looking unit that houses the display also has the center speaker and it can be removed by simply pulling the unit up from the 4 clips that hold it in place. Once removed there are 2 connectors that need to be unplugged, one for the display and one for the speaker. The display unit may be removed from the assembly and the display unit comes apart by releasing the clips around it. Once inside, the circuit board is exposed and I noticed a dry joint on one of the soldering points. I re-soldered the dry joint and it is good to go with the re-assembly of the unit. One way to look for dry joints is with a magnifying glass and look for corrosion or looseness at the solder connection. BTW the unit may be replaced for approx $420 discounted. Another clue to a dry joint issue is that when you check its operation and it fails, try flexing the unit or the circuit board to see if it is intermittent. I think that my dry joint issue was with the solder connection of the socket to the PC board.
The following 3 users liked this post by db22:
EL19 (01-10-2013), forcemac101 (12-23-2012), HEAVY_RL (06-17-2011)
Old 12-23-2012, 03:47 PM
forcemac101's Avatar
got any more tips on removing the center channel speaker? where are the four clips located on the edges? I dont' really want to destroy the fabric with my hackery...
Old 12-23-2012, 04:03 PM
HEAVY_RL's Avatar
that post is in a few threads about this topic. Its probably the best description.
There are two pics of the speaker pod here: https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/speakers-doors-876219/
forcemac (12-23-2012)
Old 12-23-2012, 11:37 PM
forcemac's Avatar
There are two pics of the speaker pod here: https://acurazine.com/forums/showthread.php?t=876219
Thanks, that helps. Is it just brute force to pull it out? Any r
Special tool to recommend?
Old 12-23-2012, 11:47 PM
HEAVY_RL's Avatar
its hard to explain technique.
Try "popping" it up with your hands.
This is my favorite tool for things like this.
Old 12-24-2012, 09:26 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
Generally with trim items like this, wedge your finger tips under the edge. (You may need a screwdriver covered with cloth to get an edge up.) Move them around the edge to find the clips. If you are away from a clip, the edge will come up easier. As you get closer to a clip, you will feel more resistance. In most cases, the clips will release as you get closer. This is true for the door sills, the CHMSL, the dome lights, the trunk lining and surely the center speaker among other things. Be sure to have clean hands or wear latex gloves as to not stain any fabric areas.
Old 12-24-2012, 04:23 PM
forcemac's Avatar
Thanks. Used a 2" plastic putty knife and it popped out...easy. I was too worried about just yanking on it, but it turns out it came out with no reservations
I have soldered a few times before, but hardly call myself a pro. I have looked a few pics of "bad" soldering joints...but was wondering if anyone can give me a second opinion on which ones to attack.
Can't quite figure out how to get links to the higher resolutions photos...photobucket seems to be resizing them
oo7spy (12-24-2012)
Old 12-24-2012, 05:10 PM
forcemac's Avatar
I think found the offending pin. It was on the power socket...there was a cracked soldering joint that matches some of the photos i saw on google. Put it back in, andit seems to pass the tapping test....it would come off or on by tapping it....no more of that so hopefully that was it.
Thanks for all the help!
Old 12-24-2012, 05:50 PM
fatty's Avatar
Can you post a pic of what you are talking bout?
Old 12-24-2012, 08:05 PM
forcemac's Avatar
It was a solder joint on the furthest left pen of the power socket, in the pics its over on theft approximately under LED2 screen print
Old 12-24-2012, 09:10 PM
HEAVY_RL's Avatar
congrats on the fix.
Old 12-25-2012, 08:31 AM
oo7spy's Avatar
Good call. You can see the discoloration to the left of it.
Old 01-10-2013, 03:45 PM
EL19's Avatar
Mine is starting to do this too. Over bumps it goes on and off and I have to tap it to cut it back on. Will attempt to see where there is a dry joint
tsx_boy
12-13-2019 08:33 PM
ITSJESTER
17
12-06-2018 02:29 AM
ExcelerateRep
10-14-2015 08:20 AM
2Quik
09-23-2015 01:03 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: Dash board display goes off an on
