Crankshaft Seal
Old Feb 21, 2023 | 12:53 AM
alfadoctor's Avatar
Crankshaft Seal
I was smelling oil on the exhaust after driving the car. I now have almost 250,000 miles on the engine and not one seal has been replaced. I crawled under looking for a leak and the leak is coming from behind the crank shaft pulley. My question is this, do we have to pull the timing belt to put in a new seal?
Old Feb 21, 2023 | 10:21 PM
altair47's Avatar
Yes, you definitely need to remove the belt, but there is a possibility that it is not the oil seal that is leaking, but the oil pump.
Old Feb 23, 2023 | 06:42 AM
Blues Legend's Avatar
And don't forget to replace the belt & crank pulley too.
(Crank pulleys hate being pulled off the taper and frequently fall apart thereafter).
Old Feb 23, 2023 | 08:19 AM
altair47's Avatar
In 8 years of working with J engines, I have never heard of this problem. Perhaps you are talking about some other engine? What taper are you talking about?
Old Feb 24, 2023 | 09:13 AM
alfadoctor's Avatar
I watched the video, and that answered a lot of questions. After cleaning up the oil underneath and going for a 20 mile drive, the smell is back. Most likely this is the oil pump seal. Now I am wondering what the cost is going to be to have this repaired. From the video the pan has to come off, so we are into an oil change, filter and pan gasket. Then the timing belt comes off to remove the front plate to replace the crank seal and oil seal., plus a gasket. Looks to be about a $1500 repair off the top of my head.
I will ask around and see what bids I get to do this.
Old Feb 24, 2023 | 06:35 PM
altair47's Avatar
The oil pan doesn't have a gasket, it's an RTV. Usually this job takes 6 to 8 hours + a few gasket.
Old Feb 27, 2023 | 09:21 AM
It's general, but typically it afflicts most Hondas. I've heard of it happening to those with C & H Series engines.
Pulling the torsional damper off the nose of the crank often results in the rubber mass separating later on. If it wears a hole in the timing belt cover, you're in big trouble.
You can chance your arm and listen out for swishing noises, or just replace the damper when it's already all in bits.
Old Feb 27, 2023 | 09:37 AM
Gimpies-Daddy's Avatar
I had a problem with an intake manifold seal, which caused a lot of burning oil smell. Check into that, too
Old Feb 27, 2023 | 05:55 PM
altair47's Avatar
The only car with this design in the US was the Honda Prelude, so the problem you describe affects less than one percent of Honda cars in USA. It's not most of Hondas.
Old Feb 28, 2023 | 06:47 AM
altair47's Avatar
The intake manifold does not have a single oil passage and it cannot smell oil in any way, if you have problems with the intake manifold gasket, then the maximum that you will get is a code for a lean mixture.
Old Feb 28, 2023 | 07:46 AM
alfadoctor's Avatar
I plan on getting further into the engine compartment today and see if I can pinpoint where the oil is coming from. Then I will get a couple of estimates on getting it repaired.
As to the crankshaft pulley, it was replaced around 200,000 miles with a new one.
Old Mar 27, 2023 | 07:52 PM
alfadoctor's Avatar
UPDATE: The two shops I checked said that the timing belt assembly will be part of the repair. One shop uses Aisin parts and the other doesn't. The one that uses the correct parts was $1800 to do the seal if it is the oil pump. The other shop said $1300 if it is just the crank seal and up from there to do the oil pump seal.
Old Apr 12, 2023 | 09:32 PM
alfadoctor's Avatar
My close friend who wrenches on Jeeps and other cars said to put a few ounces of brake fluid in the oil and that should soften the seals and resolve the leak. I did that and have noticed the smell of oil has diminished somewhat. Cheaper than $1800!
Other than this one issue, the car is exceptionally reliable for a car with 250,000 miles. We are shooting for 350,000 miles.
Old Apr 13, 2023 | 06:18 AM
altair47's Avatar
Did the store explain to you the nature of the oil getting from the crankshaft to the exhaust manifold? This whole story sounds like nonsense. Regarding brake fluid, this is a temporary solution that only works if you are selling the car.
Old Apr 14, 2023 | 02:31 AM
alfadoctor's Avatar
I know the brake fluid solution is only temporary and for now it seems to be working. The car never went into the sho for a diagnosis as they would have hit me for an hour shop rate to look at a leak. I plan on pressure washing that part of the engine to see if I can pinpoint the leak from either the seal or the oil pump. It is so tight back up behind where that stub axle is to see exactly where it is coming from.
zubi23
Mar 9, 2021 01:35 PM
Jckwgn
1G RDX Problems & Fixes
May 6, 2019 11:42 PM
Saint Croix Guy
1G TSX Problems & Fixes
Apr 1, 2013 12:40 PM
EnvyAce
May 20, 2008 12:18 PM
nickbeee
1G CL Problems & Fixes
Sep 23, 2007 05:58 PM
