Climate Control Light Replacement
Old Nov 10, 2011 | 10:05 AM
white08RL's Avatar
4th Gear
I bought a 2008 RL back in May. It was in the shop 3 times to get some of the lights for the climate control panel replaced. One of those lights went out again yesterday. I'd like to replace the bulbs myself but couldn't find detailed instructions on removing the trim around the panel (it looks like once this is done, only some screws need to be removed). I'd appreciate some help with this. Also, can LED's be used instead of bulbs for this? Thanks.
Old Nov 10, 2011 | 12:09 PM
white05rl's Avatar
Maybe this will help:
https://acurazine.com/forums/showthr...lb+replacement
If you use the Radio Shack bulbs, I'd be curious to know how they look. I just did my heated seat bulb and felt a little stupid paying $6 for a cheap little bulb. I also wonder if an LED can be used.
Old Nov 10, 2011 | 02:21 PM
white08RL's Avatar
4th Gear
Thanks. I did see this post. Unfortunately, it didn't provide the details to remove the trim pieces around the climate control panel and the link in the post to the Honda website doesn't work.
Old Nov 10, 2011 | 02:44 PM
EL19's Avatar
It says in that link he provided to remove the radio assempbly, then remove climate control panel from the assembly by removing four phillips head screws that attch it to the radio. It then says to pry the cover away from the climate control unit and the control board where you access the lights is available. Hope this helps
Old Nov 10, 2011 | 03:44 PM
white08RL's Avatar
4th Gear
I need help with the first step, how to remove the two silver trim pieces on either side of the climate control module and radio. I'm guessing they are just snapped in but I'm not sure how to remove them without breaking them.
Old Nov 10, 2011 | 03:45 PM
HEAVY_RL's Avatar
I like how white05 and white08 RL are helping each other. :racist: LoL.
I do love 2 minutes searching in ...
Old Nov 10, 2011 | 03:47 PM
white05rl's Avatar
I have the instructions in a PDF but don't know how to post it.
Old Nov 10, 2011 | 03:55 PM
white08RL's Avatar
4th Gear
Thanks HEAVY_RL! I did try searching Google and didn't have any luck. You just saved me another trip (or two) to the dealer.
Old Nov 10, 2011 | 03:57 PM
HEAVY_RL's Avatar
Well shit, glad I could help.
Google is all about key words, its an art. LoL
Old Jan 4, 2015 | 02:34 PM
jomasonvt's Avatar
5th Gear
I will be doing this as well next weekend. Did anyone figure out if you can use LED bulbs or something that lasts longer?
Old Jan 4, 2015 | 10:04 PM
Maintenanceman's Avatar
^ just scroll down this topic and you can find the led option of the bulb replacement.
https://acurazine.com/forums/audio-b...-713113/page2/
Old Jan 25, 2015 | 07:15 PM
08RLTech's Avatar
I replaced all of mine at once. Though they come in packages of 2 so I had to buy 6 from Radio Shack. Easy DIY fix. I didn't have to remove the leather trim on either side of the center. Good luck
Old Mar 21, 2015 | 03:57 PM
SKATER1's Avatar
Smile Replace bulbs
Originally Posted by white08rl
i bought a 2008 rl back in may. It was in the shop 3 times to get some of the lights for the climate control panel replaced. One of those lights went out again yesterday. I'd like to replace the bulbs myself but couldn't find detailed instructions on removing the trim around the panel (it looks like once this is done, only some screws need to be removed). I'd appreciate some help with this. Also, can led's be used instead of bulbs for this? Thanks.
go the dealer and get the right bulbs. Replace them all. It's about 5 or 6. Again replace all of them !!!!!!!!!!!!!!!
Old Mar 21, 2015 | 07:26 PM
oo7spy's Avatar
^This guy. Buy your brakes from ebay and your LEDs from the dealer...
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
wusty23jd
Sep 24, 2015 11:41 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
