Cleaning exhaust pipe?
05 Acura RL
I just got my RL last month and since it is used it has a bunch of black funk build up all over the chrome exhaust pipes. Does anyone know if its possible to clean off. If so, is it easy and what cleaner do you use. Thanks in advance for any info.
Eagle 1 Nevr-Dull FTW!
I have used 0000 Iron wool on the tips to take off the black stuff. It works great. Test in a small area first but I have never had any scratches from using them.
The cloth is soaked with the polish, so no. All you need is some elbow grease and the dirt comes right off.
You didn't have to buy it online, you know. Any major auto store carries it. Bought mine at AutoZone.
I just use either a dab of 3M swirl polish or a cleaner carnuba wax on a paper towel. Takes it right off. The better question is WHY there is always the black soot on the tailpipes. Supposedly this was an issue with the '05 and they "fixed" it by using a longer tailpipe. But I have an '07 and it happens just the same. One thing I have noticed is the soot takes longer to build up when I dont use Exxon or Mobil brands of gas (same company), so nowadays I fill up at Shell instead.
my car has 45k miles on it and I 've had it for about 3 months. I suspect the tips were never cleaned, but they weren't that bad at all, just some minor soot that came off very easily.
Originally Posted by rlerman
use 0000 steel wool (home depot has it cheap) and some fantastic or any other multi-surface cleaner, it will easily take all the black junk off and won't scratch.
LL
Originally Posted by CL6
Pardon me if I'm out of date but I believe there was a 'fix' introduced to cure, or at least conceal, this issue.
However, the issue was actually carbon/soot buildup on the rear bumper. Modified exhaust tips were provided on some 2005 RLs to make up for it. It's not an issue on 2006-up.
RL Exhaust Pipe Cleaning
Friends, I have found the easiest and most effective way to remove the carbon and heat disoloration stains from the exhaust tips is a product called Stainless Steel Brightener made by Cerama Bryte (ceramabryte.com) - or try your local kitchen appliance shop as it's used for cleaning the stainless steel kitchen hobs. All you do is apply a thin coat to the effected area (I use a small paintbrush) wait 45 seconds and then wipe of with a clean cloth or paper towel - it removes everything like magic!, no elbow grease, no polishing, no hassle! Have been using for over 2 years now on my '05 RL and my exhausts tips look like new.
My only car is a Bus
1 Post
Of course. I thought you were talking about carbon build-up. Sorry!
Thanks for the reminder!
05 Acura RL
Still having trouble getting the soot off. I used the Neverdull to no avail. I tried the Fantastik but I didn't have the brillow pad. Still hardly any of it coming off. Any one else have this same problem?
Sounds like it's time for the steel wool, dhag.
05 Acura RL
Okay so I finally fixed it. I used the 0000 steel wool with Fantasik. Had to use a little elbow grease but they look pretty good. I couldn't get the inside part of the exhause cleaned but I didn't try that hard. Thanks guys.
johnpancakes014
04-08-2016 06:47 AM
joflewbyu2
10-08-2015 11:16 AM
IIDXholic
10-08-2015 07:53 AM
