Check engine light blinking
Old Apr 5, 2016 | 05:37 AM
Wyke Dee's Avatar
9th Gear
I recently noticed my car engine sign keeps blinking and my car smoking.I only changed the oil recently and have never had the issue.
My car is an Acura RL 2006.
Kindly assist
Old Apr 5, 2016 | 05:44 AM
JasonK's Avatar
09 TL SH AWD /w TECH
Kindly assist
What do you mean by your car is smoking? Could be you have an oil leak that dripping onto the exhaust and the exhaust is burning it off. I would check for any oil leaks first. Engine light flashing might be due to misfiring is the valve cover gasket is gone and your spark plugs are burning off your oil. Kinda hard to help you with no pictures or proper description.
Old Apr 5, 2016 | 05:54 AM
Wyke Dee's Avatar
9th Gear
Thanks JasonK for the response. I have checked for any possible oil leaks. Unfortunately none.
The main problem is the blinking light and vibration when driving
Old Apr 5, 2016 | 09:08 AM
teh CL's Avatar
Did you get the car scanned to see what the codes are?
Old Apr 5, 2016 | 09:17 AM
oo7spy's Avatar
Have you checked your oil level?
You really need the codes. Google says the blinking CEL indicates misfire which shouldn't be ignored.
Old Apr 5, 2016 | 11:48 AM
08KBP_VA's Avatar
Too many possibilities here...need definitions...what do you mean smoking? The exhaust or from some other location? Im guessing by vibration do you mean bucking or hesitation if so could be plugs or coils? As others have said get the code scanned and btw the more unburned fuel you dump in the cat the more expensive this repair can get
Old Apr 5, 2016 | 01:50 PM
RL_Coastin's Avatar
How many miles? Check your oil level and like everyone has already said, get those codes read. Flashing check engine light means misfire, can be as simple as bad spark plugs or worst case scenario, a bad motor. Have a trustworthy mechanic check it out, best of luck!
Costco2
2G TSX Problems & Fixes
Mar 31, 2019 02:21 AM
georgiaboy22n
Apr 4, 2016 11:43 AM
Midnight Mystery
1G RDX (2007-2012)
Mar 22, 2016 12:16 AM
mattyacura
Jan 25, 2016 06:00 PM
tahtolindo1
Jan 15, 2016 09:18 PM
