Car won't start, just clicks
Old Jul 13, 2025 | 03:52 PM
Relyk's Avatar
A few months ago my car started sometimes just making a single click when trying to start it. For most of the time since then it would for right up on the second try. Eventually that turned into several tries, and now it won't start at all.
I tried replacing the starter cut relay as that was quick and easy. I then took the better in to be tested. It was questionable and 4 years old, so I replaced it.
Neither of those fixed it, so I'm assuming it's actually the starter, but wanted to see if anyone on here could confirm or has other ideas before I go through the effort. Thanks
Old Jul 13, 2025 | 05:29 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Check your battery cables at both ends. Also squeeze the cables as you slide your hands along the length of the cables. There have been instances where there has been internal corrosion in the battery cables. Something else to try is a couple of light taps on the starter itself. This works sometimes, if you are stuck.
Old Jul 15, 2025 | 01:39 AM
Nomgle's Avatar
This is one of the standard ways that starters fail - the solenoid starts to stick.
A replacement starter will probably solve your problem 👍
Old Aug 14, 2025 | 02:54 PM
Blues Legend's Avatar
All Hondas do it eventually.
It's usually the main relay. You can usually re-solder the connections by re-melting them. Or buy a new main relay.
Abelardo Ochoa
1G CL DIY & FAQ
Dec 18, 2019 11:30 AM
Jaysfan5432
1G CL Problems & Fixes
Apr 1, 2008 08:39 PM
TLO03
1G TL (1996-1998)
Jul 31, 2005 09:31 PM
tool001
Dec 27, 2004 10:35 PM
txathlete
1G TSX Problems & Fixes
20
Oct 14, 2004 12:11 AM
