Can you change drl bulb
I have an 06 Tech and shortly after I got the car I swapped them for Phillips Silverstar Ultras. While they are noticeably whiter when employed as high beams I wouldn't say they look like the HID's. I'm not sure the Silverstar's have any better spread when employed as high beams. In fact, I'm not sure they illuminate the road ahead quite as broadly as the stock bulbs (which I noticed where also Phillips). The Silverstars seem to concentrate the light in a tighter circle ahead of me.
When functioning as DRL's they are somewhat whiter than stock but I believe any bulb is going to look yellow at the reduced power that is applied as a DRL.
LL
Sorry I don't have any pics but easy to say that they are certainly not the same as HIDs,but their color (when used as highbeams) is a lot less yellow than the standard lights. since they are much whiter than the standard lights they also have better contrast. I have not noticed dispersion differences between the PIAA and OEMS. Its a neat , noticeable upgrade IMO.
Originally Posted by RL06tech
Yes I swapped mine for PIIA high intensity Halogens. You'll be glad you dud since they match nicely with the HIDS.
Does the wiring of the car support a higher-power, high-intensity bulb? I'd be concerned about frying something underhood. Some high-power bulbs call for upgraded wiring harnesses.
Rob144
Rob144
Rob144
Also, anyone have any experience with the SilverStar Ultra bulb?
Thanks,
Use a bulb that is DOT approved for on-road use and you shouldn't have a problem. Many "high output" bulbs are just higher wattage bulbs and are not approved for on-road use (per the NHTSA, "The maximum wattage at 12.8 volts (design voltage): 70 watts on
upper beam, and 60 watts on lower beam.") and may be a problem for the wiring as it may not have been designe do to power higer wattage bulbs for long periods of time.
LL
LL
In fact, whether credible or not, I cannot say, but there are stories of people burning their cars up with high wattage bulbs. Philips used to have an automotive headlight forum, and there was the occassional guy that would install 80/100 watt bulbs without upgrading the wiring harness, and the car would literally catch on fire. One guy lost his brand new Olds Alero that way (allegedly).
I have tried the Silver Stars (not the Ultra) and they work fine. Basically a whiter light, probably not much brighter than standard halogen bulbs, but seem so because of the color. They definitely did not have the life of a standard halogen bulb, and they were expensive. Best deal was a two pack at WalMart of all places, under $40 for two 9006s.
Silver Stars conform to US FMVSS for headlights, and are not overwattage bulbs. I am guessing the Ultra is the same way. It may be the analog to the standard halogen xtravision bulbs, which put out 20-30% more light than a standard halogen. Ultras claim 25% more light than regular Silver Stars.
What kind of life did you get? Also, I thought the RL bulbs were the 9005's.
Originally Posted by Treblig
Chas2,
I neglected to say that my SilverStar experience has been from using them my 2G Legend for a few years, which have 9006 and 9005s!
LL
