A/C Controls
Old Oct 24, 2005 | 01:07 PM
paul_philly's Avatar
A/C Controls
When I use the climate control and want heat, I must go into the climate control screen to turn off the AC. Anyone know of a simpler step?
Old Oct 24, 2005 | 01:26 PM
hondamore's Avatar
I believe that the A/C will shut itself off when the system is calling for heat unless you are in defrost mode which keeps the A/C on to dry the air prior to heating it.
Old Oct 24, 2005 | 05:30 PM
NorCalRL's Avatar
I just turn the temperature up.
The fact that it is working in conjunction with the AC just means that it is "conditioning" the air. In other words, it's taking moisture out of the heated air.
Old Oct 24, 2005 | 06:22 PM
Nocturnal's Avatar
I drive without the AC on most of the time. I just wish it would still change the fan speed automatically like the S used to do.
Old Oct 24, 2005 | 08:08 PM
rirl's Avatar
You can use the voice control to turn AC off. Just press the botton and say
"air conditioner off" and it will confirm it and turn it off. You can also set the fan speed in the same manner - "fan speed _" Good Luck!
Old Oct 24, 2005 | 08:17 PM
SPUDMTN's Avatar
has been here awhile
Actually, it is my understanding that most vehicles with climate control keep the air conditioning running at all times, whether it is blowing hot or cold air. The air conditioning de-humidifies the air and prevents the windows from fogging up (and no, I'm not talking about just defrost). So, in most cases (if not, all) the air conditioning will be running full time, be it -3 or 103 degrees outside, unless you manually shut off the air conditioner.
Old Oct 24, 2005 | 08:27 PM
Interesting...everyone is happy with the heat temperature even with A/C on? Just by default I have always turned off the A/C when using heat...never even gave it a second thought.
Well, that was my "something new" learned today. I'll try it out and report back, but thanks for your replies.
Old Oct 24, 2005 | 09:26 PM
wasabe918's Avatar
leaving the AC on while heating, doesnt that burn more gas?
Old Oct 24, 2005 | 10:40 PM
Nocturnal's Avatar
Yes although it should burn less gas then when cooling hot air. I don't really understand why Acura doesn't allow you to just turn of the AC and keep the rest on automatic. It's really not that good for you anyway to sit in dry air. It's odd that the fan speed isn't regulated automatically anymore once you turn of the AC. Not sure which cars besides Audis have an 'econ' setting that leaves everything automatic except AC.
Oh well.
Old Oct 25, 2005 | 02:03 AM
Rich in NC's Avatar
Unemployed or retired?
Just leave everything on auto year round. The system puts very small demands on the AC during cold weather. It is a balanced system that makes use of de humidifying when needed. The system is really quite smart. It also makes allowances for where the sun is if left on auto.
Old Oct 25, 2005 | 08:41 AM
Rob L's Avatar
office monkey
you can use voice. just say "a/c off"
I have never been a big user of auto climate control because every time i see the a/c is put on when in auto and always thought that was wrong. now that I read the stuff in this thread and see it is designed to do that and is ok maybe I should change my mind on this stuff. I always want my cars to have auto climate control even though I never use it. heh
Old Oct 25, 2005 | 09:24 AM
1HOT NSX's Avatar
This is why we still see people driving a modern car with fogged up windows. It's been in every owner's manual since the late seventies/early eighties - leave the A/C on while operating the heater to keep the windows free of fog. Try pushing the "Econ" button that some Mercedes and other cars have and see what happens. I believe most people don't read the owner's manual when they buy a car.
If you leave the system in Auto it will regulate the air temperature and moisture content perfectly.
Old Oct 25, 2005 | 09:28 AM
Rich in NC's Avatar
What I meant to say in my reply above is just because the AC light is on doesn't mean the AC compressor is on. The old "economy AC" button is not needed as climate control systems have gotten a lot smarter.
Biggie_B
May 27, 2025 05:51 PM
knight rider
Mar 4, 2016 08:59 AM
hashbrown
Sep 29, 2015 12:13 PM
adreano17
Sep 29, 2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
