Burning oil but very slightly
Old Sep 30, 2025 | 10:04 AM
Gabe448's Avatar
4th Gear
I recently acquired 2007 acura rl with 75k miles on it ive put 4k miles since owning the vehicle and i notice its been burning a little bit of oil in between oil changes.i change my oil every 3k miles and the car burnt through a quart and a half of oil in between that.Is that normal? If not any possible help or any advice would be greatly appreciated on how to mitgate it
Old Oct 3, 2025 | 03:02 AM
DanL07RL's Avatar
First of all, changing that often is wasting tons of money. Today's synthetics go 10,000 easy.
Second, my daughter's 07 RL burns oil at 225,000 miles, but not that much. Suspect the prior owner(s) didn't care for the car properly.
Old Oct 3, 2025 | 12:10 PM
EasyLoveRDX's Avatar
Try doing the next few oil changes with Valvoline Restore & Protect. Many have reported this helps piston ring seals which reduces oil getting pushed up into the combustion chamber.
Oil is cheaper than metal.
Old Oct 4, 2025 | 08:09 AM
Blues Legend's Avatar
I found cleaning the PCV on the cam cover helped on my BB8 Prelude.
They were the first (H22A) with FRM (carbon fibre) bores and used to drink oil at higher mileages. But having too much crankcase pressure certainly didn't help either.
Old Oct 4, 2025 | 01:39 PM
Gabe448's Avatar
4th Gear
My oil changes so far have been with restore and protect. Hopefully itll help solve or atleast just reduce the burning a bit.also i drive the car hard so i think it justifies the 3k mile interval
Gabe448's Avatar
4th Gear
I will replace the pcv and post an update on oil consumption
Old Oct 5, 2025 | 04:39 AM
DanL07RL's Avatar
Was not aware of this product. Will use it next change and thereafter. Thanks!!
Old Oct 6, 2025 | 12:01 PM
No problem. I honestly assumed it was snake oil at first - but there are tons of internet testimonials about it fixing oil consumption issues.
The key is you have to the next few oil changes with it and the problem gradually gets better - it's not an instant fix.
Old Oct 14, 2025 | 08:40 AM
Is it OK with VTEC lost motion adjusters?
IIRC, one of those oil additives used to f them up. Which is why Honda says never use additives....
Old Oct 14, 2025 | 12:20 PM
It's not an additive - it is a different type of oil altogether.
I generally never use oil additives - if the car needed them, they'd already be in the oil itself.
Old Oct 18, 2025 | 07:21 AM
That's handy to know - or might be!
Bit of a rare product over here, by the looks of things.
kriskalest
Jan 21, 2016 09:30 AM
terryt5231
Jul 5, 2010 07:55 PM
Rich in NC
Nov 29, 2006 09:10 AM
TerminaderTL
Aug 17, 2005 03:13 AM
MSB128
1G TSX Problems & Fixes
Sep 3, 2003 06:34 PM
