Brake question 06 RL
Old Jun 16, 2019 | 11:01 AM
Madakushka's Avatar
4th Gear
Hello Acurazine! Just a quick question. I changed my front brake pads today for the first time on this car and when removing the bottom bolt from the calipers I had quite a bit of brake fluid pour out. My assumption is that this isn't normal but figured I would ask the gurus. Also given that it only happens when the bottom bolt is pulled, and stops when reinserted fully, where might this be stemming from?
Thank you un advance and happy fathers day!
Madakushka
Old Jun 16, 2019 | 11:23 AM
not normal; perhaps someone over tightened the lower bolt and pierced all the way through the caliper...
Old Jun 16, 2019 | 12:07 PM
Madakushka's Avatar
4th Gear
So you're saying I should probably relieve the calipers as well then... Fun. Ty!!
Old Jun 16, 2019 | 12:10 PM
yes, I would replace, ASAP
Old Jun 25, 2019 | 02:04 PM
acura_fantacy's Avatar
The RL front caliper is not the standard Honda caliper, which bolt did you remove from the caliper?
Old Jun 25, 2019 | 02:26 PM
Madakushka's Avatar
4th Gear
Passenger side, bottom one. Whats the variance between RL and standard honda brakes? Likely replacing the calipers anyways so the more info I can be armed with the better. Thank you.
Old Jun 25, 2019 | 02:42 PM
horseshoez's Avatar
Latent car nut
It is my understanding the variance is HUGE, huge as in not even remotely compatible.
Old Jun 25, 2019 | 04:19 PM
RL uses complete different front brake design (similar to Brembo but I could be wrong). Search youtube "RL front brake pad replacement" for some very good DIY.
Don't touch the two bolts on caliper that you can see thru the wheels, rather need to remove some clips and pins to change out the pads.
Old Jun 25, 2019 | 04:59 PM
Madakushka's Avatar
4th Gear
Appreciate the information. Yeah I learned that very quickly and found the driver side much easier to replace pads knowing it was 2 punch pins and a clip. They are indeed Brembo style and dummy me was sitting there laughing bc for once I had a C clamp that wasn't broken and didnt even need the damn thing. Sadly the bleeder valve (8mm nut) is completely rounded off from the prior owner so I'm going to replace the caliper to save myself future headaches. Gg Rockauto.
Appreciate y'all responding.
Old Jun 25, 2019 | 07:21 PM
You know they sell just the bleeder valve too right?
Old Jun 27, 2019 | 08:37 AM
projektvertx's Avatar
They sell the bleeder valve on it's own. Please don't buy a new caliper because of that!
EagleEye
Jul 23, 2013 02:18 PM
deepblue626
Sep 23, 2009 09:10 AM
deepblue626
Sep 22, 2009 04:05 PM
topgear
Nov 21, 2005 10:11 AM
blxmjx
Jun 30, 2004 11:03 PM
