brake pad replacement protocol
Old Mar 30, 2013 | 06:21 PM
06RL/NBP's Avatar
Does the Acura factory service protocol require the rotors to be turned every time new pads are installed when having it done at an Acura dealer.
Old Mar 30, 2013 | 06:28 PM
white05rl's Avatar
No, rotor replacement is only required if warped OR not within spec (ie., can't be turned, etc.)
Old Mar 30, 2013 | 10:02 PM
hondaxacura's Avatar
I do not think it's required on Acura's part. If there's no vibrations/pulsing from braking, you do not need resurfacing. However, if the tech feels that it's out of spec, you will be charged accordingly; resurfacing or even a new rotor.
Besides, removing that Brembo type caliper to get to the rotor will cost you a lot of labor time.
If you are somewhat mechanically capable, watch this video.
Old Mar 31, 2013 | 01:28 AM
06RL/NBP's Avatar
Old Mar 31, 2013 | 06:40 AM
rlerman's Avatar
If you are somewhat mechanically capable, watch this video. 2005 Acura RL Front Brake Part 1 - YouTube
What do you mean? Caliper is held on with two bolts. 2 mins with breaker bar. It's no different than any other car I've worked on. I haven't done fronts, only rear so far, very simple.
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
gqdabien
Sep 8, 2015 11:41 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
nishant11
Sep 2, 2015 10:34 AM
