Brake flush-help please!
Old Jul 11, 2011 | 04:04 PM
acurod's Avatar
Going to do a flush tomorrow along with changing my front pads. I cannot find how much fluid will be needed. Does anyone know how much DOT3 brake fluid the 2005 RL will take for a system flush?
Thanks!
Acurod
2005 RL
Old Jul 11, 2011 | 04:38 PM
alfadoctor's Avatar
Are you going to flush all the lines or just the fluid reservoir? I would figure two small bottles to do the whole system, or a quart. Be sure you watch the fluid level very carefully. If you run the reservoir out of fluid then you have air in the system and that can be a nightmare to get out.
I believe the recommendation is to use pressure to flush the lines and not pump the master cylinder.
Have you ever done this kind of work before?
Old Jul 11, 2011 | 07:04 PM
acurod's Avatar
Brake flush
Thanks AlfaDoctor. My plan is to flush the entire system. I am new to this but it doesn't seem too hard?? I have changed pads before but not flushed the system and changed all the brake fluid.
Acurod
Old Jul 11, 2011 | 07:11 PM
getakey's Avatar
Wasn't there a recall to replace the Master Cylinder seal if non-Honda fluid used?
Probably need to get the Honda fluid unless you know the recall has been performed.
Old Jul 11, 2011 | 07:34 PM
05TSXPAT's Avatar
If want to do it right at home, I would suggest you get the MV8020 Brake Bleeding Kit from Mityvac.
http://www.mityvac.com/hq_images/MV8020.jpg
Its easy to use if you are by yourself and its inexpensive at 30 to 50 bucks. I just did my brakes this weekend and it was a snap.
Good Luck
Old Jul 11, 2011 | 07:35 PM
acurod's Avatar
Yes, I had the recall performed, but all they did was check the Master. They didn't flush the system with new fluid. My car has 43,000 so I think it's time.
Acurod
Old Jul 12, 2011 | 02:16 PM
DanL07RL's Avatar
Getting a power bleeder will make that job a LOT easier, and make sure you bleed in the specific sequence called out in the manuals--lf frt, rt frt, rt rear, and lt rear..
My dealer says any DOT 3 or 4 fluid is OK--you don't have to use Honda stuff. I use ATE gold.
Old Jul 20, 2011 | 09:06 PM
kssod's Avatar
Just spend $100 and have the dealer do it.
Old Jul 20, 2011 | 10:59 PM
acurod's Avatar
Brake flush complete!
Did the job yesterday -- followed posted instructions on changing the front pads (used Wagner ceramic pads), then had a helper pump the brakes while I flushed out all the old fluid and at the same time added the new Honda DOT3 fluid to the Master cylinder. Total cost $40 for the pads and $16 for 2 pints of brake fluid (used 1 1/2 pints). Took me about an hour to do.
Thanks again to the board for great info!
Acurod
2005 RL
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
