Brake fluid leaking from piston?
Old Sep 19, 2012 | 04:14 PM
sanjeev2010's Avatar
I'm hoping someone can steer me in the right direction for this.
Driving home the other day, the low brake fluid warning came on, followed by no brakes. Had the car towed home and checked front brakes. I noticed that the passenger side front rotor was very unevenly worn (outer surface very thin compared to surface facing the engine). Pulled out the pads and noticed that brake fluid appears to be leaking from the pistons on the caliper. Could not see any leaks anywhere else.
Are there seals in the piston that could be leaking (if so, how do I take care of this) or do I need to replace the caliper completely?
Old Sep 19, 2012 | 05:41 PM
getakey's Avatar
you should be able to get a rebuild kit
I don't have a link, but should be fairly easy to find
Old Sep 19, 2012 | 09:45 PM
Matt W's Avatar
Probably not related but did you have master brake cylinder recall done?
IBankMouse
Jun 13, 2020 12:53 PM
SidhuSaaB
May 30, 2020 12:40 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Cexarin
Sep 23, 2015 07:43 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
