Before you decided to replace your power steering pump things to look for first. i went through a epic journey to fix my issue and hopefully someone would find this helpful
If your car starts to make a whining sound when you turn your wheel.
check for cracks on the hose from the reservoir to the pump, usually it's a sign it's sucking air. replace the 2 seals from the inlet of the pump
I found a crack on my hose and had to use good old gorilla tape with those metal rings you tighten with a screw so air doesn't get in. but not too tight or you will crack the old hose.
like me I crack the hose in half and had to use gorilla glue and 4 metal rings
while I wait for parts to be order.
see below for pictures
Before over tighten metal rings<br/>
After my hose crack in half! <br/>
Replace 2 seals on the power steering pump.
this is the Weirdest thing I have encounter that i couldn't find on google or on here.
If you power steering doesn't turn and it takes a lot of force to turn and you don't hear any whining noise.
locate the power pump and unscrew the top section of the high pressure hose.
you will now see a pin in the middle. push it down 20 ish time or more.
i believe this is the fluid regulator.
Metel pin
after pushing it down a couple of times, I put everything back in and started the car. I couldn't believe the wheels freely turned from lock to lock! a lot of money.
Rather than put some tape and a bunch of hose clamps, just replace the hose and the two o-rings. In your pictures, the power steering pump is clearly leaking, so you might as well get all the seals for the pump and reseal the pump as well.
It was a temporary fix while I order parts from Florida.
parts are really hard to come by in canada even at the dealer, they were back order for 2 months....in the 2nd picture you can see the new hose replace
Is it still working now after doing this? I'm having the same problem after a timing belt replacement and was thinking of trying this but if it's not a permanent fix I won't.
My 2008 RL whines a lot from the power steering pump area when I start it cold, but after warming up a bit the problem goes away. Does this rule out the power steering pump and o-rings? There is also no additional noise when turning the wheel.
