Battery Replacement 05 Rl
Old Oct 22, 2010 | 01:31 PM
southybird's Avatar
Hey all!
I got the brakes done on my car the other day and they were telling me my car was slow to crank, anyways i declined the new battery because i was in a rush... Now the battery is definitely conking out on me, can I replace the battery myself or will the electronics go south on me if i attempt to do this, any advice would be appreciated.
Thanks in Advance.
Old Oct 22, 2010 | 01:55 PM
getakey's Avatar
I replaced mine. MAke sure you have radio and nav codes handy. No data will be lost, just need to re-enter codes.
Also, look carefully at the battery - it is a flush top. The cables will not fit correctly if you do not get the same type.
Old Oct 22, 2010 | 02:19 PM
Chris Acura's Avatar
Just remember the battery group size 25.
Old Oct 22, 2010 | 04:25 PM
rlerman's Avatar
get the battery from the dealer if you can, they were running some great deals a while back when I bought mine. $80 or so for three-year 108 month pro-rated.
Install is simple as noted above. just need nav/radio codes.
Old Oct 24, 2010 | 07:45 AM
kssod's Avatar
My 06 battery was replaced free last year at the dealer. They have a pro rated warranty. They also can connect your power to a trickle charger , or separate power so that all your settings are not lost during the install
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
