auto headlights not working
So when i purchased the car in may 2011 i was driving on the highway and it was almost dark and the headlights came on. At first i had no clue what was going on until i looked in the manual and found out it was normal. Ever since then i have tried numerous times to adjust the settings to auto and i can't seem to get the lights to come on. Is there a diagram so i can see if i have it in the right slot. Idk i guessn im going to have to take it to the dealer hopefully the warranty covers it
Thats where you lose me bro... what are you lining up?
If the switch is in Auto, and the MID is set to the right sensitivity and it gets dark or you pull in a garage your lights should come on.
If not, and you turn your switch to the "on" position and the lights work, then you have a problem.
Don't call him "bro".
I was referring to the headlight notification upon turning the car off with the lights on "auto" in the 2005. That's the only model that does it.
I have seen other threads that claim the exact same thing. I agree that the sensitivity settings are not exactly intuitive. Bronx, what if you put a sheet of paper over the sensor? Do the light's turn on? It is in the middle of the dash behind the center speaker.
Lol u guys are hilarious but yea thats exactly how i had it set up and in the mid setting i hadvit on high and it still didnt come on. Im going to try that paper scenario tonite when i pull into my garage. If thatvdiesnt work do you guys think i will have to come out of pocket if i take it to the dealer ? Im still under warranty until 100k
I happen to go through a tunnel and i tried the auto setting and it actually worked this time. I was in totally shock. I still made a appt with the dealership for monday and i have a loaner car reserved for me. Could it be that maybe the sensor went bad and thats why it didn't work?
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
