Asked for radio code and battery was not disconnected or dead???
The other day I started my car like normal and the radio was asking for the code. The navigation system worked but not the radio. I entered the code and it is hasn't happened again.
Is this a sign of the battery starting to go? I have read enough threads about how the RL can start having electronic gremlins when the battery gets weak.
Ok. I'll put it on a charger tonight to make sure it is as charged as it will get. If/when it happens again I'll replace the battery. I work at a Honda dealer so I'll probably just get the OEM battery. Is there a better option than OEM? I know there aren't a lot of aftermarket options because it needs to be flat.
Better is subjective. I would go with the best balance of price and warranty. If you didn't work for a dealer, I would include availability in that mix too.
Link with available options: https://acurazine.com/forums/second-...attery-863206/
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
scionxb3003
Sep 14, 2015 01:52 AM
