ANC working or not?
ANC working or not?
How do I know if ANC is working or not?
I know it is working by default, I tried turning it off and on,block the two front mic, do not hear any difference.
I had a 2009TL as a loaner, same thing, using the diag mode I changed between ANC off and on, do not hear any difference.
ANC is always on. If the car is running, and you put your finger or thumb tightly over the front mike, you will hear the ANC working out of phase; a bunch of subwoofer pulses that will disappear immediately after you remove your thumb from the mike.
And as Tampa noted in previous thread, don't be surprised if this is moved to the Audio Navigation Electronics section
Dealer time, unless you put your thumb over the wrong mic, not the HFL mic. The ANC mic is a small plastic square in the headliner with hole in it. There is a similar one in the rear near the reading light
OK, found it.
Now When I put my ignition in Accessories mode, turn the diag on using the radio 1 - 6 buttons, choose ANC off I hear a continues ham from the speakers.
I can only really tell the difference at hwy speeds. With radio turned up to about 15, put your finger over the square on the headliner, just in front of the controls where the garage openers are. I can hear a distinct rumble when I do this, almost as if there is more hwy noise. When I take my finger off of it, it gets quiet.
I did some tests today, blocked the hole and payed more attention to the noise.
When plugging the hole you can hear the exhaust and engine noise that the ANC masks.
Even closing the ANC during drive using the radio diagnostics brings up the low level noise.
mada51589
05-03-2022 08:54 PM
Luis J. Rodriguez
09-12-2015 10:00 PM
ahsm
09-09-2015 08:35 AM
