ANC stopped working
Old Dec 15, 2005 | 09:34 AM
autofill's Avatar
ANC stopped working
The car sounded as if ANC had stopped working. I can no longer tell the difference of the noise level between covering the ANC hole in the front and leaving it open. I was wondering if ANC is sensitive to outside temperature since it has been very cold recently. Did anybody else experience this?
Thanks.
Old Dec 15, 2005 | 10:30 AM
vp911's Avatar
Mine still works and it is snowing right now...
Old Dec 15, 2005 | 11:37 AM
jftjr's Avatar
'06 RL
Have you tried disabling it and seeing if it makes a difference? Turn it off in the Audio settings -- just disable "AudioPilot" and drive the car for a while.
Old Dec 15, 2005 | 11:48 AM
vp911's Avatar
I thought that audiopilot is for the ANC - but members here corrected me - AudioPilot turns up the volume of the radio when you are at higher speeds. It compensates for the noise as you speed up. This is a seperate system from ANC.
Old Dec 16, 2005 | 12:50 PM
autofill's Avatar
I don't know if there is a way to turn on or off ANC after the car starts. I tested it by covering the ANC hole and I used to be able to tell the difference after doing just that. The car will go to the dealer to figure out what had happened to ANC.
Old Dec 17, 2005 | 12:35 AM
jftjr's Avatar
'06 RL
Well ya learn something new everyday. The blurb on the Bose website seemed to suggest they were one and the same.
Old Dec 17, 2005 | 07:50 AM
vp911's Avatar
^ Yup, I thought they were the same for the longest time.
mada51589
Jan 9, 2025 04:40 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
dlknight
Sep 3, 2015 07:54 PM
