ANC stopped working
ANC stopped working
The car sounded as if ANC had stopped working. I can no longer tell the difference of the noise level between covering the ANC hole in the front and leaving it open. I was wondering if ANC is sensitive to outside temperature since it has been very cold recently. Did anybody else experience this?
Thanks.
Thanks.
Originally Posted by jftjr
Have you tried disabling it and seeing if it makes a difference? Turn it off in the Audio settings -- just disable "AudioPilot" and drive the car for a while.
I thought that audiopilot is for the ANC - but members here corrected me - AudioPilot turns up the volume of the radio when you are at higher speeds. It compensates for the noise as you speed up. This is a seperate system from ANC.
mada51589
05-03-2022 08:54 PM
