Amount of Differential Fluid for RL 2005
Old May 19, 2013 | 11:21 AM
dragonkiss408's Avatar
Hi guys,
can you guys tell me how much DFSP fluid is needed for my RL 2005? i believe there is a front and rear differential chamber
Thanks guys,
Appreciate your helps
Old May 19, 2013 | 05:40 PM
djkurious's Avatar
Check here:
https://acurazine.com/forums/2g-rl-2005-2012-76/rear-differential-oil-change-497458/
The rear takes tranny fluid and I can't remember if there is a front differential.
I used Mobil 1 for the transfer case.
Also check this link for the transfer case:
https://acurazine.com/forums/2g-rl-2005-2012-76/transfer-case-fluid-change-867457/
Old May 19, 2013 | 10:29 PM
oo7spy's Avatar
The differential no longer takes tranny fluid unless you have a stock of Z1. Use DPSF in the diff.
Old May 20, 2013 | 03:35 PM
dapqam's Avatar
007spy is right. ATF was the proper fluid in 05 but now the ATF fluid has changed and you have to use SH-AWD (DPSF) in the differential. I have an 06 that I changed on Saturday. Back section takes about 0.8 and front section 2.8 litler/quarts. Capacities are listed in the owner's manual. I ran the rear wheels up on ramps and then jacked the front up until the car was level. Then just fill the sections up until they overflow. Remember to use new washers and make sure you open the top plugs first so you don't drain the fluid only to find that you cannot get the top ones open.
Old Aug 6, 2022 | 11:22 AM
Gimpies-Daddy's Avatar
My local Acura dealer (Crown Acura, Henrico, Virginia) tells me specifically that the 2005 and 2006 Acura RL, although the 2005 and 2006 RL used to use ATF-Z1 these two model years now use the ATF-DW1 (ATF-Z1 replacement) in the rear differential. I bought DPSF anyway, based on Acurazine recommendations.
Does anyone know the SPECIFIC answer? Is there an Acura bulletin or site referring to whether the 2005 or 2006 RL should get ATF-DW1 versus DPSF?
Old Aug 7, 2022 | 04:21 AM
deepa1600's Avatar
Your local dealer is incorrect, you should use Honda/acura Dpsf(dual pump fluid) in all shawd rear differentials, DW1 for Automatic transmission and gear oil for transfer case. My advice is to always use oem fluids for these above mentioned items (with the exception of transfer case), specially for automatic transmission always use oem fluid.
Old Aug 7, 2022 | 08:45 PM
altair47's Avatar
Honda says API GL4 or GL5 gear fluid, This is an ordinary angular gearbox with two gears, use any GL5 80W90 fluid. I fill Valvoline 80W90, capacity ~500-550gm.
Old Aug 9, 2022 | 11:04 AM
Official information?
I am confident that you are right. However, do you have a written confirmation, like an Acura technical service bulletin, an official Acura website link (not just a dealer website), or a written Acura chart that says this?
Old Aug 9, 2022 | 11:09 AM
deepa1600's Avatar
See the pdf file.
Old Aug 15, 2022 | 10:47 AM
See the pdf file.
YES, that's what I want to show to the parts guys. Thank you.
ZekeR7
May 30, 2019 05:32 PM
cauraLT101
Aug 6, 2014 10:16 AM
Buffa
15
Oct 28, 2013 02:27 PM
elemgee
May 27, 2011 09:49 PM
