AFS Sensor
Old Nov 10, 2018 | 09:21 AM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
AFS Sensor
I can't find similar info so i'm making a thread for this.
1. There are other sensors behind all wheels that look just like the AFS one that is on the rear left.
I am confused. How many AFS sensors are there? I always read here that the rear left is the one that is the AFS sensor. what makes the headlights swivel. Plz if someone know and can clarify.
2. My left headlight was flickering then now it turns off after a few flickers. If I turn the headlights off then on, it come back on, then after a while, same.
3. I took out the rear left AFS sensor, and sure enough one of the springs is barbecued. So I just replaced it with a spring from a pen. Now, the AFS light no longer blinks, and I no longer get an MID message about it, but it's just there on the bottom right: on & not blinking. If I buy a spring, will the lights swivel again?
Help, I need clarifications before buying expensive sensors. And I also don't want to buy the Doorman sensor for a hundred bucks and find out if doesn't solve the problem.
Old Nov 10, 2018 | 10:13 AM
projektvertx's Avatar
https://acurazine.com/forums/second-...fs-fix-930302/
Old Nov 10, 2018 | 04:10 PM
RL09's Avatar
Which point are you replying to A? No making sense in my head.
My battery is in top notch. I did mention a spring inside the sensor was barbecued, among other things.
Old Nov 13, 2018 | 10:21 PM
RL09's Avatar
Could a bad AFS sensor cause the headlight to flicker and/or turn off?
Old Dec 26, 2018 | 10:49 PM
Acura13egend's Avatar
7th Gear
Could be a dying bulb, ignitors or ballasts that will cause flickering
Old Dec 27, 2018 | 05:08 AM
7th Gear
This may help
https://acurazine.com/forums/second-...e-help-970366/
Old Dec 27, 2018 | 10:38 AM
RL09's Avatar
Thanks Acura13egend, actually I did post in that thread, I have news I'll reply in it shortly.
Old Dec 27, 2018 | 11:18 AM
7th Gear
I had a similar problem when my hands free link started draining the battery, had the passenger side flicker and dash light up, took it to a Honda dealership and had everything cleared, fixed the problem for me
Old Dec 27, 2018 | 04:19 PM
RL09's Avatar
What do you mean by "everything cleared"? but anyway my HFL thank God is still hanging in there. The key is not to turn off, or on, the car while you're using it. Otherwise it risks getting stuck.
Today my mechanic covered the new 20 dollar afs sensor with silicone. Still happily swivellin!
Old Dec 27, 2018 | 04:39 PM
7th Gear
Any codes that were being shown due to the battery being drained
noynek
1G TL (1996-1998)
May 21, 2018 03:05 PM
UW RL
Jul 8, 2006 12:01 AM
bkw
Aug 28, 2005 07:49 AM
konst_ms
Jul 18, 2005 12:01 PM
aziz
May 16, 2005 11:40 PM
