afs headlights
Old Mar 13, 2021 | 01:13 PM
eligold's Avatar
afs headlights
i have the 05 rl in which i know had issues with the driver side light not staying on well i changed the ballast and the harness inside but for some reason this damn light turns on and after a few minutes it turns off again and its only on the right side i also checked the connector to make sure i was getting power and it was i checked the pins inside connector to make sure nothing was broken or loose but nothing its still doing the same thing i finally decided to check the wiring but i wanted to get some ideas and opinions before i go thru that long process
Old Mar 13, 2021 | 05:22 PM
have you tried swapping igniters and bulbs and ballast from left headlight to right to see if the issue still persists?
Old Mar 14, 2021 | 09:18 AM
sccrxer's Avatar
Did you try a new bulb?
Old Mar 15, 2021 | 09:18 AM
eligold's Avatar
headlight issue
yes i have tried i replaced the ballast thinking in the beginning it was that it worked for a little while and then did the same thing again i replaced the igniter and i believe the bulb also only thing i didnt replace was the afs motor that moves the light but i see it moves so im not sure its bad if all else fails i guess i will have to try and trace back the wires and see where they go its possible its broken or shorted somewhere but i see that is a job in itself in which i dont have alot of time now so again i am hoping for some answers to the problem i know the 05 rl had problems on the right light and i believe the 06 or 07 had it on the left i need help with this??? im also trying to recalibrate and relearn the vsa and awd since i replaced the pump brakes still work but not the way they should anyone have any idea or possibly the software to service this
Old Mar 16, 2021 | 05:11 PM
sccrxer's Avatar
I would do what thoiboi suggested and swap the good side to the bad side and see if the problem stays in place or if it follows the parts you moved.
Old May 7, 2021 | 01:18 AM
kennyRL's Avatar
did you ever fix this? i have almost exact problems with VSA and AFS
Maverick2050
3G RDX Problems & Fixes
May 23, 2021 07:03 PM
josh jones
Feb 21, 2019 10:49 PM
0408TLBoii
Mar 18, 2012 12:50 PM
mennis876
Oct 7, 2010 10:48 PM
4u2nv
Apr 15, 2005 10:40 AM
