Acura RL 2009 need help I don’t know what to do
Old 05-23-2022, 01:24 AM
bayboy's Avatar
My Acura RL starts well, on low speeds I can hear some scratching noise it shifts well and suddenly isn’t able to change speeds anymore that’s comes with a little kick. After that D starts flashing sh-awd message pop up it says also check you transmission system and AFS will flash too . If I turn off the car and drive later it might be back to normal or still be fcked 50%
what should I do guys ?
Old 05-23-2022, 04:55 AM
DanL07RL's Avatar
Had a similar occurrence in my '07 when I first had it. Limped into the dealership and they had it fixed in less than an hour......no charge (under warranty?) Something about hitting a bump just as a shift happened.....at least that was their story. Could also be a funky battery.
Good luck
Old 05-23-2022, 02:23 PM
rlx015's Avatar
Check this post: https://acurazine.com/forums/second-...luster-974028/
Not sure if you noticed if the"D" would flash, but if it won't shift gears, I suspect one of the gear sensor/switch is going bad because I had the same lights come up...
1. Check the battery and both connections to eliminate that as an issue
2. Transmission relay check at the dealer - they should be able to troubleshoot and give you run down of what they find... then decide where to fix it.
Old 05-24-2022, 08:39 AM
Blues Legend's Avatar
I'd wager that stall speed alert christmas tree is due to a shonky battery.
Does the car handle like a FWD pig when it happens?
I put mine on a battery conditioner and not had it since. Thing is, it's happened after a long run when the battery ought to be fully charged, so it's likely some sort of electrical spike.
Old 05-27-2022, 04:34 AM
DanL07RL's Avatar
So OP, did you ever get this resolved.......inquiring minds want to know!!
Old 05-27-2022, 08:01 AM
deepa1600's Avatar
You need to change your 2nd, 3rd, 4th gear pressure switches. I think that is the problem.
Old 05-29-2022, 11:05 AM
TonyCD's Avatar
That was my problem, and it also shot out multiple problem messages like this. But, important, in the Messages section of the big central screen, it also gave a specific trouble code that pointed directly to the 2nd gear pressure switch (the one that fails most often). See if you have a little icon in the corner of your big screen that looks like an envelope. That tells you there's a trouble code waiting for you to read it.
Rsy
03-04-2017 09:08 PM
acura3204
07-24-2009 11:00 AM
christopher1
02-08-2009 07:41 PM
Wayne0221
01-19-2009 04:30 PM
becker800
02-06-2008 01:38 PM
Quick Reply: Acura RL 2009 need help I don’t know what to do
