A16 Time or Not
A16 Time or Not
My extended lease runs next month. Let's do an intergrity test for a A16 service.
A) Hit reset and clear the MID code and turn the car in.
B) Turn the car in with the MID code
C) Have the service done
I'm opting for C this Thursday. I either will end up keeping the car after Thursday or try to strike a deal for a new TL with SHAWL.
B)
Blah! If you are going to return the car, I would not bother doing the service. I highly doubt the Acura inspector will deem it necessary to fulfill this service to honor the lease return obligation.
Since you are considering the TL SH-AWD (which means you don’t mind the new bold styling) why not consider the 09 RL too?
Please inform us on the decision when you get back from the dealership!
09 TL SH-AWD with Technology Package $42,235
09 RL with Technology Package $50,300
I would consider them in the same ballpark. You also have to consider the TL SH-AWD a “hot commodity” due to decent sales on the new TL models and people who understand value of the SH-AWD (supple & demand will kick in & checking the 4G TL members sign-in the going rates $37-$38). The 09 RL on the other hand is more a “rarity” and seemingly in no demand (I have seen the same black 09 RL on the dealer lot for over 3 months) therefore I am sure the dealership will accommodate any reasonable offer ($41-42 range?). For that reason, if Professor is looking at the new TL SH-AWD or opting to keep his current RL, looking into leaping over to the RL isn’t that far fetched (if he can accept the new bold styling that is..
Well...he'd have to accept the bold new styling of either one, no!?!? Lol...
Yeah, you're right...but I don't think they'll drop the RL down that much, no matter how long it sits. I guess it depends on what the dealership paid Acura for it.
I'm sure this is all covered in the initial agreement that bears your signature. Dealers are not dumb and will know what has and has not been done. Follow the agreement and you will have no questions.
The first code is either A or B, A requires an oil change only and B requires an oil and filter change. The second code (Sub Item) will contain letters 1-6:
1.Tire rotation
2.Air Filter and Micron filter (Cabin Filter) replacement, and check the drive belt
3.Transmission fluid, and transfer fluid (if equipped)
4.Spark plug replacement, timing belt replacement (if equipped), inspect water pump and valve clearance
5.Engine coolant replacement
6.Differential fluid replacement
1.Tire rotation
This is a typo in the manual that has existed from 2005 to 2009. I suppose they depend on the techs to know that procedures tell them to change the filter when they change the oil.
FWIW, the same terminology is used in other Acura and Honda manuals, such as the TL and MDX, the CRV, the Civic, etc. it just says to Change engine oil with an asterisk that says
If the message ‘‘SERVICE DUE NOW’’ does not appear more than 12 months
after the display is reset, change the engine oil every year.
so the A16 service require the oil change and all the things below? at what mileage interval does that service come into play? i wasw thinking about doing all those fluids plus the brake fluid at 60k miles. thanks!
Rog
Rog
1.Tire rotation
1.Tire rotation
Instead the MID code determines what service details need be performed.
The MID code is compiled based on mileage, driving style and sensor information.
If you check the manual for the service codes you will see all the normal service details, but the alpha numeric code assigned by the MID bundles these service details for the service call required.
thanks for the info guys! so A16 means oil change, rotate tires and change diff fluid only right? to do everything it would be a code of A123456? just want to get it right so i dont go overboard in doing stuff.
any info on how to reset afer oil change?
Skirmich
Sep 15, 2015 06:41 PM
