60k Fluid Changes
Old Aug 5, 2013 | 12:23 PM
scottyrocket53's Avatar
60k Fluid Changes
Hi,
I did a search for this and found a smattering of info regarding what fluid changes you do at 60K. I bought the car with 53K and I am sneaking up on the 60K mark. I bought new tires and changed the brake fluid. What does everyone suggest?
Old Aug 5, 2013 | 12:29 PM
if you just bought the car, I'd change every fluid..
-transmission fluid.
-coolant
-oil
-differential
-brake
-etc.
Old Aug 5, 2013 | 08:42 PM
oo7spy's Avatar
Change your:
Engine oil: 5w-20, 0w-20 if way up north, 5w-30 if temps get over 100.
Transmission fluid: Acura ATF-DW1
Transfer case: (?)80w-90(?) hypoid gear oil
Rear differential (2 chambers)- Acura SH-AWD or Honda Dual Pump II fluid
Check/top off:
Brake fluid
Coolant
Power steering (only use Honda power steering fluid)
All recommended fluids are listed at the very end of the manual except transmission and diff. Those have been updated since the manual was printed.
Your 60k service calls for engine, trans, transfer, and diff.
Old Aug 5, 2013 | 08:46 PM
^good shit!
Old Aug 5, 2013 | 08:53 PM
MrKev's Avatar
A 60k service at dealer will get you...
Oil change
Tire rotation
ATF
Transfer case fluid
Rear diff fluid
Air filter
Cabin filter
Alignment
Old Aug 6, 2013 | 10:04 PM
Thanks for all the input.
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
