2012 (KB2) Possible bad wheel bearing?
Acura's All Day
Hi all... Before I replace the wheel bearing I just want some opinions. For a few weeks now I have had a humming like noise the starts when driving around 40 and increases in volume the faster you go (2012 Tech w/ 88,xxx miles). As you are driving the noise is coming from the front left/drivers side... When going through left curves, the noise increases and does so significantly more if you make a few quick sharp jabs to the left. I have had 2 local Acura Dealerships inspect the car, both dealerships have indicated that during the tests on the bearings there seems to be nothing wrong, they have inspected the suspension, rotated tires and even drove it with different wheels on it and to no avail, nothing makes the noise go away. Alas, they say "Mr. Brinkley, it certainly shouldn't be making the noise, our best guess is the front left/drivers side bearing is just beginning to go bad but we can't give you a definitive answer". From what I have read, if you turn left and the noise increases then it would be the right side bearing and vice versa. But you can literally hear this noise on the left hand side of the car and it increases on the left hand side of the car during left hand curves. Before I order the parts and have my cousin install them, I just wanted outside opinions on which side you all feel it may be and if you all feel it could potentially be something else. The car has brand new Continental ContactExtreme tires on it with less than a thousand miles (tires was the Acura dealers second guess) but they ruled that our switching rims and tires driving it and the car isn't wearing them either. Any help is greatly appreciated. Thanks in advance
How's the alignment? Might be the axle too if not the wheel bearing
Acura's All Day
Its actually had 2 alignments in the last 6 months, once because I knew I was getting new tires and the second time... Because I am picky and my steering wheel wasn't perfectly centered the first time lmbo. But nonetheless the alignment is perfect on it now.
Make an appointment and ask your service advisor for a guy that has the most experience. Ask the mechanic go with you for a test drive, that way he/she can experience the noise according to your description. Usually the mechanic pretty happy when they talk to a car enthusiast and they will put extra effort in diagnostic the problem.
projektvertx (04-28-2018)
Both wheel bearings on my RL were toast after the dealer did the TC replacement under warrant. They replaced one without too much pressure as there was a definite DRONE sound when driving. Sound would increase with speed.
The other wheel bearing was done at a different dealer after complaining about droning again as I thought it was the centre shaft bearings ($$$$$).
From experience with our 2007 Odyssey and it's wheel bearing issue, it does tend to get louder with speed and can sound like BAD tires.
Could also be CV or inner shaft joints if more prevalent when turning.
Acura's All Day
Acura's All Day
Acura's All Day
Alignment Report
I dont know if this helps anyone, but this is my alignment report. I dont quite know how to read it, but according to the techs, everything about it is fine.
I also had a noise that was apparent at certain RPMs and it turned out to be a heat shield. At least something else to look at as I thought it was the alternator or belt tensioner.
2020 Acura RLX Advance
How much does it cost to replace both front wheel bearings? I would not think it to be a major job. I know on older RWD cars it was a simple and cheap procedure. In my college days I replaced them myself on my Chrysler Cordoba right out in the street in NY (I was in college a long time ago!).
My 2012 RL has 113k miles and quiet. My sister's brand new Audi developed a very pronounced roar at speeds above 70mph. Audi 1st blamed it on the OEM Continental tires and just rotated them. The noise persisted and I took the car back to Audi. On the 2nd visit Audi said there was a recall on front wheel bearings. Problem solved.
Acura's All Day
I had them inspect those too as I was ran to the side in a parking lot by an 18 wheeler awhile back and my front left wheel ran over the side of one of those islands in a parking lot. I damn near cried when I got out of the car to inspect everything. Nonethless, those were in the clear too. The only damage caused by that scenario, one of the clips that hold the plastic piece that runs along the wheel area was torn out. Althought, I have a crunching/plastic noise when going over/hitting uneven places in the road after that, but they also said there is nothing that they can find that causes the noise on that either <inserts eyeroll>
Acura's All Day
have you got another quote from indi shop that specialize in Acura/Honda car? it def is way cheaper than dealer.
