2005 RL Remote engine start
Old Sep 10, 2007 | 10:26 PM
rogermohan's Avatar
3rd Gear
When I press the "lock" button twice on my remote, it starts my RL engine automatically. I thought RL doesn't have this feature? Does anyone else have this problem or know how to disable it?
Old Sep 10, 2007 | 10:31 PM
plastikman's Avatar
Did you buy your car new? If not I would say its something someone before you had installed. I have an 06 and just tried it out, it does not start on my car.
Old Sep 10, 2007 | 10:36 PM
rogermohan's Avatar
3rd Gear
Thx, I brought my used, i guess they installed it.
Old Sep 11, 2007 | 05:53 AM
dwest1023's Avatar
You consider that a problem???
Old Sep 11, 2007 | 06:13 AM
lland's Avatar
It is if the car is in the garage with the doors close.
LL
Old Sep 11, 2007 | 12:43 PM
2007AcuraRL's Avatar
Gee thats GREAT news to learn that remote start is possible with the RL. I installed one on my last car, a TL, using a transponder bypass which learns the code inside the key and sends it to the car when the remote start is activated. Without that the car won't start. I have been looking for a transponder for the RL and havent come across one yet. Too bad you dont know any more details about the system installed in your car. I'd love to know what brand both the remote module and the transponder are. Was there any paperwork about it in the glove box? Its particularly interesting that they were able to trigger the remote start using the 2nd pulse in the Acura body control module (which is what locks and unlocks the doors).
You should also check to see if it has an "On" function, which would let you get out of the car and keep the engine running. Some remote starts have this feature. No one can steal the car because the engine dies when the brake pedal is depressed unless the key is in the car. This is a particularly useful feature on an extremely hot or cold day when you are running into a store a moment and want to keep the car running. Not sure how it might be activated using the Acura fob. On an aftermarket fob, you would activate it by pressing and holding down the remote start button for 2 seconds while the engine is still running (at least with a Compustar remote start).
Old Sep 11, 2007 | 08:32 PM
rogermohan's Avatar
3rd Gear
I just checked, it does have the "On" function you stated. But the engine still dies when i press the brake pedal even when i have the fob with me.
Old Sep 11, 2007 | 09:29 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
You may have to turn the ignition switch before you press the brake pedal. THat's how the DEI remote starter worked in my old Acura Vigor.
Old Sep 11, 2007 | 10:20 PM
neuronbob's Avatar
I WISH I had that "problem" on my RL. That comes in handy in those nasty Cleveland winters.
Let us know if you find out which manufacturer does that, I'd be interested in finding and installing that.
Old Sep 12, 2007 | 08:28 AM
henryr01's Avatar
'10 A5 & '07 TL
Take a look at this on Directed's website. http://www.directedstore.com/cgi-bin/commerce.exe?preadd=action&key=555DW&reference=/cgi-bin/commerce.exe%3Fsearch%3Daction%26keywords%3Dall%26 searchstart%3D0%26template%3DPDGCommTemplates\Full Nav\SearchResult.asp%26category%3DB_IN
I had one of their Remote Starters on my wifes Yukon and she loved it. I had "assumed" that we couldn't use a remote starter on the RL because of the keyfob. I'm thrilled to hear that someone has done it.
In my case, I'll most likely but one in the TL first. You have to know where your priorities are!
Old Sep 12, 2007 | 12:47 PM
Yeah I've seen that transponder but we have to check with Directed to see if its for our 2nd Gen RL. The discription references Prelude which hasnt been made in many years so I think that transponder is for older cars. I have the Compustar alarm/remote start which I pulled out of my TL before trading it in. Unfortunately the contact I used to have up in Canada where I got the unit from has left the company. He was a source of very good wiring and electrical info for the Acura. He used to also be a member on these forum boards, but I dont remember his user name or I could eamil him about it.
At the very least I will be reusing the Clifford intelisensor and adding it to the factory alarm, which doesnt have any tamper or glass sensor protection. Since I have the wiring diagrams for the RL, I know which wire to attach the shock sensor to trigger the factory alarm. Its on my list of upcoming mods.
Old Sep 21, 2007 | 04:25 PM
pete94tsi's Avatar
I know this post is older now but has anyone figured out which bypass module will work for the RL. It's not hard to get a remote start to work but the car still needs to be able to be secured when you walk away. If you just put a key in a bypass box under the dash the car could be started anytime, that wouldn't be good. Please post if you have any verified info on this subject.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
