2005 RL 3 Problems
Old Jun 12, 2014 | 05:18 PM
jzanone's Avatar
7th Gear
2005 RL 3 Problems
I recently acquired a 2005 RL with about 110,000 miles on it. Folks on this forum have been great in helping resolve a Nav problem (it was dead and I wound up replacing it).
There appears to be three other problems that have come to my attention.
  1. There is a buzzing or resonation coming from the engine compartment (passenger side) when accelerating.
  2. At the rear passenger wheel/suspension I am hearing a rattle on rough surfaces.
  3. The doors continue to lock intermittently after locking the first time. There does not appear to be any pattern to this.
If anyone has suggestions as to what is causing these problems (more annoyances than anything else), I would appreciate the help.
Thank you in advance.
Old Jun 12, 2014 | 05:29 PM
rlerman's Avatar
1. Hard to say without hearing it.
2. Pull tire and check brake components. Could be broken clip underneath rear bumper, there are two and your bumper will rattle if they aren't secured.
3. ?
Old Jun 12, 2014 | 07:53 PM
tlmaster1's Avatar
Check rear sway bar links
Old Jun 12, 2014 | 07:54 PM
tlmaster1's Avatar
And could also be the door lock actuator
Old Jun 12, 2014 | 08:35 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
Parking brake cable has been known to rattle.
Door lock actuators. I have had 3 of the 4 replaced in my car. 2 exhibited the lock / unlock phantom as well as a groan.
Old Jun 13, 2014 | 08:18 AM
oo7spy's Avatar
+1 on the brake cable.
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/d-012-rear-right-suspension-noise%3B-e-brake-cable-tightening-772060/
Old Jun 13, 2014 | 10:38 AM
titomang's Avatar
3. You can try disconnecting the lock actuator and connecting it again. Could be it's not plugged in until clip clicks if it's been worked on before. The same symptoms happened to me and it solved the problem.
Old Jun 13, 2014 | 12:02 PM
db22's Avatar
Check the dogbone looking link on the rear axle.
SidhuSaaB
May 30, 2020 12:40 AM
agupta3224
May 23, 2017 08:30 AM
RobbDizzle
Oct 15, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
