2005 Moonroof switch
Can someone with a 2nd gen RL tell me of the Moonroof switch is supposed to light up when the lights are on? All the other switches in the overhead cluster there are lit up except for the moonroof switch right in the middle.
Just wondering if I need to replace a bulb.
Originally Posted by Martini
Is there a "one touch" button available for the moon roof?
Now, can anyone answer my question about whether the switch should be lighted with the lights on?
no it does not
that moonroof button does not light up. i have one blown light it is in the a/c control pass side button. i will leave due to i do not want my dash torn apart for a bulb! hope this helps
2012 Cadillac CTS-V Coupe
The moonroof switch, which does have a one-touch feature, is lit. I noticed it pulling out of the garage this morning.
Received 2,329 Likes
If so it may need to be reprogrammed. Did you recently disconnect the battery? You may need to reprogram your one touch windows as well.
Here is how you do it:
For the moonroof, push the open button and hold it, keep holding it after it has opened all the way for a few extra seconds. Repeat to close, hold it a few seconds after closing.
Same goes for window switches. If this doesn't help, we'll try something else.
I would imagine it requires popping off the map light covers. That will expose two 11mm (?) bolts that you would need to remove. Then the whole assembly should pop out.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
xsilverhawkx
09-28-2015 06:51 PM
