06 RL idle bumping
Old Jun 18, 2014 | 07:36 PM
kingofbytes's Avatar
06 RL idle bumping
Hi All,
I'm on a roll taking y'all's time so I figured I'd try it again.
Lately, the old girl has been going a little wacky at red lights. You know the drill - stop at the red light and wait for it to turn green.
Virtually every time it will drop 100-150 rpms (from default and functional 750rpms to 600-650rpms) and want to gently lurch forward. This happens whether AC is on or off so I know that's not a primary trigger.
I've been reading about IACV and EACV's on this site. I've also read that drive by wire systems don't have these. The old girl has 190K miles - is there something simple I can do? Something like TB cleaner or something? Just replace a part that's long in the tooth?
Thanks y'all!
Old Jun 19, 2014 | 12:00 PM
oo7spy's Avatar
Get new spark plugs. It has fixed the same issue on another member's car before.
Old Jun 19, 2014 | 04:14 PM
Thanks oo7spy....one question. I just replaced those August 2013 along with timing belt and water pump. These were the ones I used:
Napa NGK 6994
Still think I should replace them? If so, I'm thinking of these:
Bosch Iridium SPark Plug
Thoughts?
kingofbytes
Old Jun 19, 2014 | 09:14 PM
oo7spy's Avatar
Probably not the plugs if they are that new. Next caller?
Old Jun 20, 2014 | 05:11 AM
I'm going to check the coolant fluid today....I saw something on another board about that. Stay tuned.
Old Jun 20, 2014 | 07:45 AM
oo7spy's Avatar
You can bleed the coolant lines by taking the radiator cap off when cold, running the engine until bubbles stop coming out, top it off again and replace the cap.
Old Jun 23, 2014 | 09:53 AM
HEAVY_RL's Avatar
"You" replaced them or "you had them" replaced... either way something isnt right, the answer will help me place the blame
Old Jun 23, 2014 | 10:38 AM
Megatron's Avatar
Have you checked/cleaned your EGR valve. Sometimes a dirty EGR valve can cause idle issues as well.
Old Jun 23, 2014 | 07:58 PM
OK, so here's some more information:
Had slightly low coolant, put in about 1 cup. No change - idle/lurch issue still happens.
New tactic: When stopped (in D), while it's lurching and RPMs are lower, I've put it into Neutral - car climbs to about 1000rpms quickly and just as quickly settles back to the normal 750. Put it in "D" again and within seconds, after engaging, it goes into the slight lurch with lower RPMs. There are occasions when the car isn't fully warmed up yet, that this issue does not occur. However, once warmed up, it's pretty constant when stopped and in D.
I've put it into reverse as well and the issue does not seem to occur. Of course I'm not in R very long while stopped....maybe I'll try other tactics.
As far as the EGR valve goes, I haven't cleaned it nor am I aware of it being cleaned. Any tips/step by step to do that would be appreciated.
As for the spark plugs, they were replaced by my mechanic.
Old Jun 23, 2014 | 07:59 PM
One more clarifier: There is NO ISSUE when in park. Just sitting there in P, and there is no issue - it is only when in "D". Feels almost drivetrain related but I have no idea....
Old Jun 23, 2014 | 09:47 PM
HEAVY_RL's Avatar
is the charging system healthy?
Old Jun 24, 2014 | 06:22 AM
Seems OK - Is there a way to check? I just got a new battery last year - Interstate brand.
Old Jun 24, 2014 | 07:50 AM
HEAVY_RL's Avatar
First off remember we are trouble shooting based on your descriptions... we cant see or hear the car... and just to level set... a "new" to you battery doesn't mean a good battery.
Most auto centers can load test the alternator... a drop like that could be electrical or it could also be the idle air control... either way you need to get someone to check it out.
Old Jun 24, 2014 | 07:53 AM
Fair enough - I'll do that next week.
The missing link for me is why it does it only when in D and stopped. In N, it doesn't do it. Let's assume alternator is fine....what next? Idle Air?
If so, what's the process to check that?
Old Jun 24, 2014 | 09:22 AM
HEAVY_RL's Avatar
If I remember there are three bolts on the back of the opening where the intake pipe ends.
Honestly you could chase this for a while... a drop could be a load on belt driven components, it could be an issue with fuel, air, or spark...
Old Jun 24, 2014 | 09:29 AM
I'm going to post a video in a couple of hours. ..once I shrink it from 150MB. You'll see the exact behavior I am experiencing.
Old Jun 24, 2014 | 09:38 AM
oo7spy's Avatar
How old is your transmission fluid? The gear variable suggests to me the torque converter could be involved.
Old Jun 24, 2014 | 09:42 AM
HEAVY_RL's Avatar
Cool a vid will help, a technician will have a list of "symptoms" that lead to "steps"... so keep in mind its a process.
Old Jun 24, 2014 | 11:24 AM
Can't upload zipped MP4
Guys,
I'm trying to upload a zipped MP4 at 10.2MB. The extracted size would be 13MB.
I keep getting this error message:
vBulletin Message
Your submission could not be processed because a security token was missing.
This error most often occurs for one of two reasons. Trying to upload a file, or photo which is too large, and it took too long. Otherwise it can occur if you have been on the page a long time, before submitting your post or pressing the upload button.
Please try reloading the page, and attempt your action again. If you were trying to upload an image, please make sure it falls within the site's size constraints.
Everything looks like it uploads properly and I'm under the 19MB size limit. Thoughts?
Old Jun 24, 2014 | 11:35 AM
HEAVY_RL's Avatar
I'd use youtube, photobucket, or facebook...
Old Jun 24, 2014 | 11:36 AM
I would be checking for a vacuum leak.
per your description, as soon as you put load on the vehicle, it gives a funny idle.
Old Jun 24, 2014 | 11:41 AM
HEAVY_RL's Avatar
Could be, especially if the mechanic had it apart.
Old Jun 24, 2014 | 11:44 AM
Just click the link to the video
Here's the video link below. I was sitting in a parking lot when I recorded this. As I am shifting, my foot is on the brake the whole time. I never touch the accelerator. Please look for the following:
  • Going from "N" to "D". Seems OK, then seconds later you'll see the RPMs drop to 550 or 600 (from around 750). This is the 'slight lurch'. I've shown this 3 times in a row.
  • Going from "D" to "N" initially jumps to 950 or 1000 then quickly settles back to where it belongs (750).
  • Going from "N" to "R" shows no issues. Going from "R" to "N" shows no issues.
For clarity, this ONLY happens when going to "D". And it's happening now virtually every time when warmed up.
http://youtu.be/INeZgvpBAEY
Old Jun 24, 2014 | 12:37 PM
oo7spy's Avatar
I had very similar issues on Legend #1 which I believe were combinations of different things. At one point, a mechanic found a plastic vacuum canister that had become detached from its brace and a belt had worn a hole into the side. Make sure you not only check tubes and connections, but check any containers that may be part of the vacuum system.
Old Jun 24, 2014 | 03:17 PM
Good info - Car going in on Wednesday next week - I'll mention the issue and potential vacuum leak.
Old Jun 24, 2014 | 04:14 PM
pcloadletter's Avatar
I have had a similar drop in idle, but only coming off throttle to coast, usually around 50 to 40 MPH. Some BG44K fuel system cleaner with PEA (polyether amine) helped smooth out the idle. Also, some new plugs, NGK 5787, for the KB2 3.7 helped fuel economy. Both of these seemed to mitigate the idle issue with 90,000 miles on the odometer.
Old Jun 25, 2014 | 07:23 AM
HEAVY_RL's Avatar
I feel like that drop isnt the issue as much as how low your idle is to start with... keep us posted.
Old Jul 3, 2014 | 08:11 AM
So magically, the problem has completely gone away after being at the mechanic to cut the rotors, replace the power steering fluid, and replace the propeller shaft.
My head shakes side to side - I HATE not knowing.....we'll see if the problem comes back.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
DerrickW
Nov 15, 2015 05:52 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
mdlex389
4G TL Problems & Fixes
Sep 28, 2015 06:29 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
