'05 RL gasoline
Old Mar 27, 2009 | 09:18 PM
alfaelmar's Avatar
'05 RL gasoline
I use premium (93) gas only. Any thoughts about using lower grade gas??
Old Mar 27, 2009 | 11:08 PM
037's Avatar
037
I believe that would degrade performance and eventually may cause problems.
I don't think the penny's saved will be worth it.
Want to save gas? keep RPM under 2k at all time.
Old Mar 28, 2009 | 12:14 PM
Texas05RL's Avatar
Do you seriously think 93 is really 93? Gas station owners "accidentally" put the wrong octane in the 93 tanks all the time.
Old Mar 28, 2009 | 12:50 PM
bugeye's Avatar
wat
The dealer I bought mine from told me anything above 89 is a waste of money.
Old Mar 28, 2009 | 01:04 PM
037's Avatar
037
That's why the gasoline gets tested. And if you feel your car runs worse than normal you can report the gas station and it will be checked again out of cycle.
Old Mar 28, 2009 | 01:05 PM
037's Avatar
037
The dealer probably doesn't keep his cars long enough to notice the effects of poor grade gasoline in a hi-tech vehicle.
I personally have had 3 cars and 93 provided the best performance for me. For that alone I put the higher grade.
Old Mar 28, 2009 | 01:12 PM
rlerman's Avatar
I've noticed a pinging going up hills when using 89/87, especially when starting out on a hill. putting in 91/93 solved it. It's about $5 difference per tank for 87 vs 91/93, hardly going to break the bank of anyone who drives this car.
Old Mar 28, 2009 | 01:21 PM
rmjse's Avatar
In my state, 93 octane is illegal for some odd reason. I would assume 91 is "premium" enough?
Old Mar 28, 2009 | 03:56 PM
drolds72's Avatar
The anti knock sensor should retard the timing when that happens. Is it really bad? Might want to get it checked out.
Old Mar 28, 2009 | 04:59 PM
Chas2's Avatar
The manual specifies that 91 octane (R+M)/2 "premium" is sufficient.
R=RON, and M=MON, the two methods of calculating octane. Add them together, average them and that is what you see sold at gas stations.
Old Mar 28, 2009 | 05:15 PM
rlerman's Avatar
The pinging was not bad, but I could hear it. I was using 93, figured I try 89 to see what would happen. After about two tanks of 89, I could hear it. I switched back to 93 and within 1 tank it was gone.
BTW, only some sunoco stations in NJ sell 91, everywhere else that I have seen, it's only 93. 91 is about 3-5 cents cheaper than 93.
Old Mar 28, 2009 | 07:00 PM
037's Avatar
037
93 is the new 94 for Sunoco stations. When they got rid of 94 they added 91 and pushed the prices from 94 to 93 and from 93 to 91.
Old Mar 28, 2009 | 08:06 PM
woodek's Avatar
My car DAMN sure knows the diffrence. Just looking at the tach after 100 miles lets me know it aint 93. She runs rough.
Old Mar 28, 2009 | 10:06 PM
neuronbob's Avatar
Oh not again.
This is a frequent discussion, which always ends in "use what Acura tells you to". Not being harsh, just honest.
Old Mar 28, 2009 | 11:20 PM
470hpGS400's Avatar
I fill up 11-13 times a month so it does add up, still....I use 91. Need that hill climbing ability.
Old Mar 29, 2009 | 11:07 AM
rlerman's Avatar
Huh? 11-13 times/month? assuming you get 400 miles per tank, that's about 4500 miles/month or over 50k per year.
Old Mar 29, 2009 | 11:11 AM
470hpGS400's Avatar
Yep, unless I'm on vacation.
Old Mar 29, 2009 | 10:05 PM
gbriank's Avatar
Oh not again.
Bob:
Let's put this thing to bed... Ahem...
Can you use lower octane gasoline? Yes. Will it reduce the performance of the engine? Yes. Will it damage the engine? No, sensors take care of this. Will you get the same fuel economy? NO! The engine and command computer will burn more fuel to try and make up for the performance loss.
Final result? No cost savings. Stick with Premium. End of story.
Old Mar 30, 2009 | 07:15 AM
db22's Avatar
I tried an experiment in my 05: I have run 91 for many years but I had to use mid-grade once. I could not tell the difference in performance and my MPG increased. My journey is 40 miles each way and constant speed, no traffic. I have performed this test on many occasions and asked my fried to do the same. He experienced the same - no performance change and better MPG.
I know this goes against all that is written and the science behind it and I would argue against it if I didn't do the test myself but I cannot refute the findings. All I can say is try it and let us know, one tankfull will do no harm.
Old Mar 30, 2009 | 10:56 PM
rtr's Avatar
rtr
RL owner
i use 91 or 92
Old Mar 30, 2009 | 11:09 PM
nore03's Avatar
Randy is the Future
400 miles a fill up?? Wow ur lucky i must drive like crap cause i get like 310 per fill up. I only fill up about 4 or 5 times a month though. My girl put 89 in my car once when i let her use it and i felt the difference and asked her what she used and almost freaked out when she said regular. It performs like crap with 89 gas so 93 i a definite all the time.
Old Mar 31, 2009 | 01:17 AM
getakey's Avatar
I agree - there is a dif between 91 and 87 (that's premium to reg in CA)
cycdaniel
Dec 17, 2019 10:58 AM
ceb
ILX
Sep 27, 2015 10:56 AM
vbgregg
Sep 11, 2015 05:38 PM
Jan 4, 2005 02:30 PM
