'05 RL 3rd brake light spontaneously works??
this happened to my 04 tl in the past, do we have a 3rd brake light switch just like the TL or is it different? please help, don't wanna get pulled over something stupid like this...
Are we talking about the brake light in the rear window? How complicated is it to pop off? I would like to get in there to stop a rattle my subs are causing.
Heavy, speak to me man.
Sorry, had a hot date last night... yeah when we tinted my car I didnt want to cut around it so we pulled it down.
From what I remember it pops down like any trim piece, I think there were 4 clips total.
I had a body panel remover (long flat pliers) and popped it right off.
Haha... No need for apologies. Hot dates are infinitely more important than the I am (at least to you)!
On your last post was that for the OP or me? I don't understand this brake switch on the pedal.
You may have a resistive short in the switch that is allowing some current through in the "normally off" position. Theoretically though, that would cause it to be on even when the car is off. Is that true?
I don't think so. It should be on the pedal bracket.
I had the same problem. The switch is on the pedal and easy to see. I think that the switch is a double pole switch and I used the other pole. I remember removing it and taking it apart but I don't remember the details but I would start at this switch and check it with a $2.99 meter.
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
