0 compression
Old Apr 13, 2021 | 02:40 PM
Bongo Vybz's Avatar
7th Gear
0 compression
How do i fix it? My engine has 0 compression in one cylinder?
Old Apr 13, 2021 | 04:43 PM
deepa1600's Avatar
Put that cylinder on TDC and do a leak down test and check where air is coming from. If from intake then you have bad intake valve, if from exhaust then bad exhaust valve, if from oil fill cap or dipstick hole then worn piston rings. It could be bent valves or any number of things. When was the last valve adjustment done?
Old Apr 13, 2021 | 07:07 PM
dzionny_dzionassi's Avatar
With 0 information provided, I will shoot in the dark= burned exhaust valve.
trev0006
Dec 12, 2018 04:45 PM
cbrose
Mar 15, 2010 01:11 PM
May 10, 2006 01:44 PM
jermz123
Aug 13, 2004 03:45 AM
Crazytree
Oct 21, 2003 06:27 PM
