VSA concerns with changing tire sizes
Is this a concern for anyone? Especially for winters. I'm in Toronto, Canada
https://techinfo.honda.com/rjanisis/...000O00189A.pdf
Driving with varying tire or wheel sizes may cause the VSA to malfunction. When replacing tires, make sure they are of the same size and type as your original tires
No, they'll all be the same size. But I'm looking to get used rims and possibly tires and it seems like it may be difficult to make sure the size aka rotational diameter is the same as the stocks...
I think they mean if you get 17" rims.. they should ALL be 17".
if you're going down to 17" for winters, your tires should be 235/65/17. virtually same diameter as oem 18" and it won't change the look too much
your wheels should be 17x7-8. anything bigger or smaller will work but not as well
illtriniboy (11-16-2018)
Yukoncole
31
05-10-2010 09:51 PM
virtualbong
14
11-06-2005 11:26 AM
