Front strut assembly
Old Mar 27, 2026 | 07:28 AM
mm5300's Avatar
I'm looking to replace the front struts on my girlfriends 2015. I'm looking to find a good full strut assembly so I don't have to deal with compressing the spring. What brand have people used? I've heard KYB and Monroe mentioned for good brands, but they don't seem to have the full assembly for this model. Any thoughts would be appreciated!
Old Mar 27, 2026 | 10:02 AM
EasyLoveRDX's Avatar
Monroe sucks. Only KYB.
If there's no strut-plus available for your model you're prob stuck making your own assembled coilover. You could always pay a shop to do that. Get a set of KYB Excel-G struts and source some new springs (kinda crazy RockAuto doesn't carry springs)
Old Mar 30, 2026 | 06:24 PM
Thmanx's Avatar
I'll be doing a Front and Rear suspension overhaul on my 2G RDX over the summer, likely around June or July, I'll be sure to do a write up with photos when I do.
I'll be doing KYB Front and Rear shocks and endlinks from Rock Auto, with OEM Acura bushings, top hats, springs, etc. (maybe even OEM lower ball joints if needed)
When I priced it all out, Front and Rears could be done for under $800 all in, which wouldn't be that bad considering.
I intend to assemble the entire front coil assembly beforehand at my work, and do an install over a weekend when there are more hours of daylight.
Old Mar 31, 2026 | 06:54 AM
Kelsen's Avatar
I did this as well, doing the struts late in the fall of 2024 (the compression was a bitch), and although I had them, I didn't do the shocks until one was leaking last month (I am almost always alone in my car, and simply didn't feel the gradual loss.) I did not do the ball joints, the LCAs, or any other part of the suspension. I had purchased the parts (KYB) several years ago, but hadn't faced up to the work. I am glad I got the job done.
RFT!!!
Dave Kelsen
"There is a cult of ignorance in the United States, and there has always been. The strain of anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'" -- Isaac Asimov
Old Mar 31, 2026 | 08:40 AM
Thmanx's Avatar
Yeah both of my front OE shocks are completely dead and blown.
For the last few years, I used to be able to hear one side make an audible "woosh-woosh" shock damper kinda noise, but over the last 6 months, that's faded away into silence.
Both of the dust boots on either side have completely disintegrated into shreds, gunky oil residue is visible all over the shaft body, and what appears to be a metal washer is now bouncing around the top of the shock bodies & shaft, making a wonderful 'doink-doink' noise over every little bump.
When I hit a large bump on the freeway, I can clearly count the one-two-three-four natural oscillations it takes for the front end to settle down. So yeah, they done done lol.
Old Mar 31, 2026 | 09:34 AM
sounds like your bump stop is gone?
Cloud29
Mar 13, 2026 09:35 PM
travelcoin
ILX Problems & Fixes
Aug 21, 2023 05:11 PM
RummysWorld
Jun 22, 2021 09:18 AM
rpopek
Oct 27, 2008 01:04 PM
