Washer Reservoir Question
Old 10-25-2018, 11:53 AM
joeyc33ny's Avatar
I recently purchased a 2015 RDX. When I went to fill the fluid I leeks out behind the wheel well and stops at the line attached and highlighted in red. Is that normal or is the reservoir cracked or broken somewhere?
Old 10-25-2018, 11:59 AM
joeyc33ny's Avatar
Old 10-25-2018, 12:00 PM
Received 16,260 Likes on 11,971 Posts
pull the front bumper and inspect reservoir...that way, you'll know first hand if it's cracked or not.
I also believe the dipstick has measuring hashes for you to determine if full
Old 10-25-2018, 12:29 PM
Received 8,592 Likes on 6,636 Posts
sounds like it's cracked around that line..
Old 10-29-2018, 09:21 PM
awoc's Avatar
Unusual spot since there isn't anything there to rub against.Very inexpensive part. Throw in a new one! Maybe sure you grease up the oring of the pump before the install. It makes sliding in the pump much easier.
Old 10-30-2018, 03:27 PM
dave08902's Avatar
If the previous owner filled the tank with summer blend washer fluid and it froze in the winter, this would cause the tank to crack from expansion.
techtalk
1G CL DIY & FAQ
09-27-2011 05:26 PM
HuKaShI
10-18-2005 09:03 AM
Slimey
03-01-2004 10:10 PM
Quick Reply: Washer Reservoir Question
