Washer Reservoir Question
Old Oct 25, 2018 | 11:53 AM
joeyc33ny's Avatar
I recently purchased a 2015 RDX. When I went to fill the fluid I leeks out behind the wheel well and stops at the line attached and highlighted in red. Is that normal or is the reservoir cracked or broken somewhere?
Old Oct 25, 2018 | 11:59 AM
joeyc33ny's Avatar
Old Oct 25, 2018 | 12:00 PM
pull the front bumper and inspect reservoir...that way, you'll know first hand if it's cracked or not.
I also believe the dipstick has measuring hashes for you to determine if full
Old Oct 25, 2018 | 12:29 PM
sounds like it's cracked around that line..
Old Oct 29, 2018 | 09:21 PM
awoc's Avatar
Unusual spot since there isn't anything there to rub against.Very inexpensive part. Throw in a new one! Maybe sure you grease up the oring of the pump before the install. It makes sliding in the pump much easier.
Old Oct 30, 2018 | 03:27 PM
dave08902's Avatar
If the previous owner filled the tank with summer blend washer fluid and it froze in the winter, this would cause the tank to crack from expansion.
techtalk
1G CL DIY & FAQ
Sep 27, 2011 05:26 PM
HuKaShI
Oct 18, 2005 09:03 AM
Slimey
Mar 1, 2004 10:10 PM
