Manual key will not unlock door
Old Sep 8, 2019 | 09:35 PM
Sunn's Avatar
Hello, I have a 2014 RDX and the battery is dead. I've tried several times to use the manual key to unlock the driver side door with no luck. I've tried putting WD40 on the key and the lock but that did not help. Does anyone have any suggestions?
Thanks in advance.
Old Sep 8, 2019 | 10:59 PM
samiam_68's Avatar
Are you turning it in the correct direction?
Old Sep 9, 2019 | 06:40 AM
Sunn's Avatar
I've turned the key in every direction possible.
Old May 9, 2020 | 01:13 AM
TDotCord's Avatar
Bump..
I am having the same issue with a 2013 RDX. It almost feels like the lock mechanism is power assisted in some way. If that's the case, it'd be a pretty silly design. I'll call my AAA on Sunday to get it popped open if I no one else has any ideas.
Thanks.
Old May 16, 2020 | 03:04 AM
TDotCord's Avatar
UPDATE. I had AAA unlock the RDX and replaced the vehicle battery but still had the same result with the blade key. I came across a similar post on an MDX forum:
https://www.mdxers.org/threads/emerg...e-door.162825/
However in, my case. The driver's door was repaired by a body shop a couple years ago for a parking lot ding. I reached out to the shop earlier this week and they asked me to bring the vehicle in. They discovered that the pin from lock cylinder that should align and engage the lock mechanism was mis-aligned when the door was likely put back together after the repair. They fixed that the this second time. All good now.
Tyler Harteau
Sep 29, 2017 04:30 PM
aedimartino
Aug 12, 2007 03:48 AM
jgrahamiii
Jan 4, 2007 12:45 PM
sajigore
Nov 21, 2005 07:44 PM
RogerPodacter
Mar 29, 2004 08:44 PM
